I have connected HC-05 to Arduino mega and initialized the bluetooth connection through port rfcomm0. I had uploaded the code to arduino and When i try running rosserial node to subscribe the message as
$rosrun rosserial_python serial_node.py _port:=/dev/rfcomm0
I have bumped into the error below
netceilo@netceilo-OptiPlex-780:~$ rosrun rosserial_python serial_node.py _port:=/dev/rfcomm0 _baud:=57600
[INFO] [WallTime: 1486073151.351080] ROS Serial Python Node
[INFO] [WallTime: 1486073151.354630] Connecting to /dev/rfcomm0 at 57600 baud
[ERROR] [WallTime: 1486073168.457418] Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino
[ERROR] [WallTime: 1486073183.458364] Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino
How to get around this issue, i had checked the baud rates and it seems to be fine and also there is no issue in code as the code is working well with usb port.
Originally posted by Kishore Kumar on ROS Answers with karma: 173 on 2017-02-01
Comment by Humpelstilzchen on 2017-02-03:
Is your bt connection full duplex?
Did you set the right boad in the Arduino code (I see on the Linux site 9600)? Do you use the Right Serialport on the Arduino?
look at this Anser
http://answers.ros.org/question/206972/baud-rate-parameter-in-rosserial_python-arduino/
may this help
Greet
Originally posted by duck-development with karma: 1999 on 2017-02-01
Comment by Kishore Kumar on 2017-02-02:
Yes i Tried that fix as well but it didnt help
Comment by duck-development on 2017-02-11:
Did you Desolder the USB/Uart Chip from the Arduino, cause you can use ether usb or bluetooth but not the both at the same time.
the problem ist the TX line. only one Chip can drive it.
Had the same problem wih the Bluetooth Uart Bridge and my 3D printer.
