Hi, I noticed that ROS does not correctly see message files in subfolders of the "msg" folder. The add_message_files command can take a DIRECTORY command which works partly:
add_message_files(
  DIRECTORY
  msg/subfolder1
  FILES
  testmessage.msg
Both catkin_make_isolated and catkin build run perfectly but after a source devel/setup.bash, the rosmsg list command does not show this testmessage. If I change the subfolder name to something different in the CMakeLists file, cmake complaints about the missing path. Hence, the folder path is recognized partly.
The only solution I found was to move all message files out of subfolders such they are directly placed at e.g., msg/testmessage.msg. Then, the rosmsg list command shows the message.
Is there another way to use subfolders for message definitions?
Thanks!
Originally posted by inspire on ROS Answers with karma: 23 on 2017-01-31
I confirmed this (my code, which modifies beginner_tutorial to add a new msg file "Num5.msg" in a sub folder). Although msg artifact is generated, the new msg doesn't appear in rosmsg list. Used catkin_make. I can, however, use the new message Num5.msg in my ROS program. E.g. rostopic pub Num5 beginner_tutorials/Num5 1 then subscribing to it can be done without problem.
More concrete commands and result:
roscd beginner_tutorials/msg
mkdir subfolder
(edit CMakeLists.txt to add subfolder to `add_message_files`)
echo "int64 num" > subfolder/Num2.msg
cd -
catkin_make
Then,
find ./devel -iname *Num2*    --> Generated.
rosmsg list|grep Num          --> Num2 not listed.
rostopic pub Num2 beginner_tutorials/Num2 1    --> Published.
rostopic echo /Num2    --> Printed as expected.
So maybe a specific issue with rosmsg list.
$ apt-cache policy ros-kinetic-catkin ros-kinetic-rosmsg   |grep Inst
  Installed: 0.7.6-0xenial-20170217-212821-0800
  Installed: 1.12.7-0xenial-20170308-194441-0800
Originally posted by 130s with karma: 10937 on 2017-03-18
Comment by 130s on 2017-03-18:
Reported on ros_comm repo.
