When catkin_make is used , devel folder is generated along with some setup files . However, when catkin_make install is used , a new folder install is generated along with the setup files . How are these two folders different in terms of the files they contain ?
Originally posted by sam26 on ROS Answers with karma: 231 on 2017-01-31
See if wiki/catkin - workspaces answers your questions.
Edit:
I also wanted to know the difference in terms of sourcing the setup files in both these folders . How can i know when to source the files from devel space and when from install space
From the page I linked to:
Once targets are built, they can be installed into the install space by invoking the install target, usually with make install
If all packages in your source space have the required install(..) directives in their CMakeLists.txt, then there should be no difference between the devel and the install space, when running nodes from those packages.
For normal development though, I'd always just use the devel space (name sort of implies that). The install space is typically an 'end-station': you use it for deployment.
Originally posted by gvdhoorn with karma: 86574 on 2017-01-31
Comment by sam26 on 2017-02-01:
That partly clarified the question.Thank you . I also wanted to know the difference in terms of sourcing the setup files in both these folders . How can i know when to source the files from devel space and when from install space
Comment by baselink on 2022-05-23:
If I do not run the 'make install' command, I can roslaunch the package. Right? Thanks.
Comment by gvdhoorn on 2022-05-23:
make install is not a command you should use with ROS packages.
Yes, I think so. Thanks.
