The error in the subject prevents the rqt plugin from running.
$ pwd
/home/noodlerv/cws_viz
$ rospack find rqt_launch
/home/noodlerv/cws_viz/src/ros-visualization/rqt_common_plugins/rqt_launch
$ rospack find rqt_launchtree
/home/noodlerv/cws_viz/src/pschillinger/rqt_launchtree
$ rqt --standalone rqt_launch
qt_gui_main() found multiple plugins matching "rqt_launch"
rqt_launch.launch_plugin.LaunchPlugin
rqt_launchtree.launchtree_plugin.LaunchtreePlugin
$ rosversion qt_gui
0.2.32
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.5 LTS
Release: 14.04
Codename: trusty
The above example is using source but this happens also with installed binaries.
Since rqt_launchtree
is introduced later than rqt_launch
, I looked into rqt_launchtree to see if anything that qt_gui
might reference to to lead into the raised error (e.g. exact string rqt_launch
) but failed to find anything suspicious. Therefore I assume this error occurs because of the current spec of qt_gui.
Is there anyway to avoid this error without changing package name and anything that affects api and/or existing applications?
Originally posted by 130s on ROS Answers with karma: 10937 on 2017-01-30
