Hi all,
I'm relatively new to ROS so please bear with me.
I am trying to implement an extended kalman filter node from the robot_localization package.
I am localizing my robot using a Piksi RTK GPS unit with a fixed base station and an IMU. This setup gives me three useful data streams; /gps/fix (sensor_msgs/NavSatFix), /gps/rtkfix (nav_msgs/Odometry) and /imu/data(_raw until I pass it through a imu_filter_madgwick node) (sensor_msgs/Imu).
Note that /gps/fix includes GPS points (decimal degree format) which are both the single point precision(SPP) points as well as the RTK corrected points. I had to modify the gps driver so that the status information reflects the message type (SPP/RTK). Does the navsat_transform_node take into consideration whether the point is augmented or not? Does it need to?
/gps/rtkfix is relative to the base station (which is placed at a surveyed position).
From what I understand, a single SPP GPS and a single IMU can work but may not be very accurate. How would I go about including the RTK position information? Should I set the datum to the base station position or would that mess up the global coordinates?
I know I haven't included very much data or in-depth info in this post but there is quite a lot so if you need anything more specific, please let me know.
Thanks.
EDIT 1:
Below is a sample of the /gps/fix stream. The first message is RTK augmented and therefore has status == 1. The second is a SPP message and has status == 0.
header:
seq: 9355
stamp:
secs: 1484232874
nsecs: 552879627
frame_id: gps
status:
status: 1
service: 1
latitude: 59.6727308353
longitude: 10.7179627288
altitude: 97.3549933056
position_covariance: [0.0016, 0.0, 0.0, 0.0, 0.0016, 0.0, 0.0, 0.0, 0.0016]
position_covariance_type: 0
header:
seq: 9356
stamp:
secs: 1484232874
nsecs: 636842456
frame_id: gps
status:
status: 0
service: 1
latitude: 59.6727627988
longitude: 10.718035228
altitude: 122.657179707
position_covariance: [1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0]
EDIT 2:
The covariance matrices have been updated to reflect the correct and relevant info (previous edit updated). I'm not sure if I have set up the frames correctly or how I can go about outputting the gps (UTM) locations of each point. My current launch file is shown below.
<launch>
<node pkg="tf" type="static_transform_publisher" name="link0_broadcaster" args="0 0 0 0 0 0 1 odom base_link 100" />
<node pkg="tf" type="static_transform_publisher" name="link1_broadcaster" args="0 0 0 0 0 0 1 map gps 100" />
<!-- Global (map) EKF instance -->
<node pkg="robot_localization" type="ekf_localization_node" name="ekf_ontrack_global" clear_params="true">
<param name="frequency" value="30"/>
<param name="sensor_timeout" value="0.1"/>
<param name="two_d_node" value="false"/>
<param name="map_frame" value="map"/>
<param name="odom_frame" value="odom"/>
<param name="base_link_frame" value="base_link"/>
<param name="world_frame" value="map"/>
<param name="transform_time_offset" value="0.0"/>
<param name="odom0" value="/gps/rtkfix"/>
<param name="imu0" value="/imu/data"/>
<!-- RTK -->
<rosparam param="odom0_config">[true, true, true,
false, false, false,
false, false, false]</rosparam>
<!-- IMU -->
<rosparam param="imu0_config">[false, false, false,
true, true, true,
true, true, true,
true, true, true]</rosparam>
<param name="odom0_differential" value="false"/>
<param name="imu0_differential" value="false"/>
<param name="odom0_relative" value="false"/>
<param name="imu0_relative" value="false"/>
<param name="imu0_remove_gravitational_acceleration" value="true"/>
<param name="print_diagnostics" value="true"/>
<param name="odom0_queue_size" value="10"/>
<param name="imu0_queue_size" value="10"/>
<param name="debug" value="false"/>
<param name="debug_out_file" value="debug_ekf.txt"/>
<remap from="/odometry/filtered" to="/odometry/global"/>
</node>
<!-- Navsat node transform -->
<node pkg="robot_localization" type="navsat_transform_node" name="navsat_transform_node" respawn="true">
<param name="delay" value="3"/>
<param name="magnetic_declination_radians" value="0.054"/>
<param name="yaw_offset" value="1.5707963"/>
<param name="zero_altitude" value="false"/>
<param name="broadcast_utm_transform" value="true"/>
<param name="publish_filtered_gps" value="true"/>
<param name="use_odometry_yaw" value="false"/>
<param name="wait_for_datum" value="false"/>
<!-- <rosparam param="datum">[59,66727, 10.77337, 0.0, map, odom]</rosparam> -->
<remap from="/imu/data" to="/imu/data"/>
<remap from="/gps/fix" to="/gps/fix"/>
</node>
</launch>
EDIT 3:
Here is a sample message from /imu/data
header:
seq: 603
stamp:
secs: 1484232821
nsecs: 269243016
frame_id: imu
orientation:
x: 0.0909325752091
y: -0.993837356153
z: -0.00888735559103
w: -0.0237232971259
orientation_covariance: [1e-05, 0.0, 0.0, 0.0, 1e-05, 0.0, 0.0, 0.0, 1e-05]
angular_velocity:
x: 0.00298800367941
y: 0.0135341556846
z: -0.000234223185618
angular_velocity_covariance: [1.2184696791468346e-07, 0.0, 0.0, 0.0, 1.2184696791468346e-07, 0.0, 0.0, 0.0, 1.2184696791468346e-07]
linear_acceleration:
x: -0.540727223129
y: 0.0771066032982
z: -9.56023780893
linear_acceleration_covariance: [8.66124974095918e-06, 0.0, 0.0, 0.0, 8.66124974095918e-06, 0.0, 0.0, 0.0, 8.66124974095918e-06]
Originally posted by Tyrone Nowell on ROS Answers with karma: 48 on 2017-01-25
