A fixed joint has no element in the /joint_states/position
array, as it cannot change from 0.0
(it's fixed, after all).
You could probably use the pose of your EEF as tracked by TF. Something like rosrun tf tf_echo CHAIN_START CHAIN_END
(where CHAIN_START
could be base_link
and CHAIN_END
the frame that represents your EEF) should give you the transform.
Edit:
how can i plot velocity of fixed joint ??
There is no entry in any of the arrays in a JointState
message for fixed joints. Again: they are fixed. No velocity
, acceleration
or effort
for these joints.
Note: I'm describing the typical situation (such as with joint_state_publisher
with gui:=true
). Whether all drivers do the same thing I cannot say, but it wouldn't make sense to me to publish joint values for something like a fixed joint.
Originally posted by gvdhoorn with karma: 86574 on 2017-01-21
Comment by zakizadeh on 2017-01-21:
how can i plot pose for my fixed joint(joint_U26_1) like rqt_plot /turtle1/pose/x:y ??
what is a turtle1 ??
Comment by gvdhoorn on 2017-01-22:
Joints don't have poses, only link
s have poses (every link
becomes a TF frame). Plotting TF frames is slightly involved. See #q58793 for some hints.
Some other options:
Comment by zakizadeh on 2017-01-22:
how use this command ??
rxplot /tf/transforms[0]/transform/translation/x
thats not working .
rxplot
is now rqt_plot
rqt_plot /tf/transforms[0]/transform/translation/x not working .
can i use this page?? what can i do ?
Comment by zakizadeh on 2017-01-23:
what about this one??
Comment by gvdhoorn on 2017-01-23:
That page still works with JointState
messages, which do not typically include fixed joints. You'll have to plot TF frames, not JointState
msgs. The pkgs I linked in my earlier comment could help you with that.
can you write a very simple sample for that ?? i want plot pose ( x and y and z ) of link
in #q58793 wrote i shoud use pose topic parsed from the node tf . how can i do that? i cant found any sample .
Comment by gvdhoorn on 2017-01-24:
Other than tf_trajectory
and hector_trajectory_server
, I don't know of any existing pkgs/nodes that can do what you want, but in a nutshell:
- create a TF listener for the TF frame you want to plot
- convert the TF to a
geometry_msgs/Pose
and publish that
- plot
Comment by zakizadeh on 2017-01-24:
im sorry . can i plot in RViz or rqt_plot ?? which one ??
Comment by gvdhoorn on 2017-01-25:
TF frames you can show in RViz (using either the TF Display
or one of the pkgs I linked above). If you create the TF -> geometry_msgs/Pose
converter, you can use RQT to plot the individual members of the Pose
msg.
Comment by zakizadeh on 2017-01-27:
i need practical example .
