Hi,
Make sure parameter "RGBD/OptimizeFromGraphEnd
" is set to false
(default is false
) so that the robot is localized accordingly to the first node in the map (your fixed map's frame). rtabmap
will publish /map -> /odom
frame to convert the robot pose into /map
frame. For example between sessions, each time rtabmap is localized against the same location, /map -> /base_link
will be always the same (the same pose in the map independently of the odometry value).
Note that /map -> /odom
is published only when the robot is first localized. On start, make sure the robot can recognize where it is (i.e., it is actually at a real location in the map).
EDIT: Small example
Start the camera:
$ roslaunch freenect_launch freenect.launch depth_registration:=true
Create a map (clear the database and use RVIZ):
$ roslaunch rtabmap_ros rtabmap.launch rtabmap_args:="--delete_db_on_start" rtabmapviz:=false rviz:=true
When loop closures are detected, the /map -> /odom
transform should change:
Now kill rtabmap.launch
to save the database, then relaunch in localization mode:
$ roslaunch rtabmap_ros rtabmap.launch localization:=true rtabmapviz:=false rviz:=true
Move the camera in the same area than in the map, until a localization happens, then /map -> /odom
will be published again (with some values depending on where you started the camera the second time):
Note that here I clicked Download Map on the MapCloud plugin to get back the map shown in RVIZ.
cheers
Originally posted by matlabbe with karma: 6409 on 2017-01-27
Comment by natejgardner on 2017-02-01:
/map -> /odom
is always 0.000 for me. We confirmed RGBD/OptimizeFromGraphEnd
is false, and no matter where we start (we even checked the database to make sure the camera frame matches up almost perfectly with an image saved in the database), /map
and /odom
are the same frame.
Just to confirm, where is the parameter RGBD/OptimizeFromGraphEnd
set?
Comment by matlabbe on 2017-02-04:
I updated the answer. It is set internally to its default value (false). To change it, you can use $roslaunch rtabmap_ros rtabmap.launch rtabmap_args:="--RGBD/OptimizeFromGraphEnd true"
. You can also set <param name="RGBD/OptimizeFromGraphEnd" type="string" value="true"/>
under rtabmap
tag
All RTAB-Map core parameters can be set that way. To see a complete list off all parameters: $rosrun rtabmap_ros rtabmap --params
Comment by natejgardner on 2017-02-06:
Thanks for the update. Unfortunately, /map -> /odom
is still always published as zero, even when there is a loop closure. That said, there is almost never a loop closure. It seems that downloading the cloud first may be necessary? We get more loop closures when we do this, but it takes 30 minutes.
Comment by micander on 2017-02-06:
I still can't get it working. Is rviz mode required for localization? I'm using the rtabmapviz mode. It seems that loop closures are occurring (green flashes) but rosrun tf tf_echo /map /odom
still outputs zero values.
Comment by matlabbe on 2017-02-06:
Downloading the cloud in RVIZ is not necessary, it is just for visualization. RVIZ is not necessary either, it should work with or without rtabmapviz
too. Do you have a video of the problem? Which version are you using? How do you launch the nodes? You can update your question for clarity.
Comment by micander on 2017-02-10:
The project's not public but we can send you an email with the video. We're using version 0.11.11 that we built with eigen, gtsam, cvsba, g2o, and mkl. We're launching with a launch file that <include>
s a copy of rtabmap.launch from rtabmap_ros, as well as starting kinect2_bridge.
