I use the Ubuntu environment,Refer to the "ROS NDK How to cross-compile any other ROS package for Android" tutorial, compile sick_tim,./do_docker to sick_tim when I run the wrong as follows:
  ==> add_subdirectory(sick_tim)
CMake Error at /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108 (message):
  Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
  /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:315 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:106 (find_package_handle_standard_args)
  sick_tim/CMakeLists.txt:11 (find_package)
Originally posted by zzkzsmj on ROS Answers with karma: 1 on 2017-01-14
Comment by gvdhoorn on 2017-01-14:
Without more context (OS, how you installed things, what you are trying to do, which version of ROS, etc), the best I can do is that it would seem you don't have PkgConfig installed. Try installing it and see whether that helps.
Comment by zzkzsmj on 2017-01-17:
Hello, I was in the Ubuntu environment, the use of ROS NDK compiler errors,
Comment by gvdhoorn on 2017-01-17:
Please update your original question (use the edit button/link) and give us enough information to help you. What exactly are you trying to do, and what set of steps led to the error message that you copy/pasted.
I have no direct experience with the NDK integration, but from the error message I would say that the docker image that is being used does not have PkgConfig installed or CMake can't find it. I recommend you open an issue here.
Well, thank you very much.
Currently we don't support using PkgConfig with the ROS NDK, you will need to use a workaround to specify the correct variables for the library you need to use (in this case libusb). Here's an example on how we do that for another package.
Originally posted by Gary Servin with karma: 962 on 2017-01-17
