I am getting an error when trying to install cv_bridge on Ubilinux (based on Debian 7 Wheezy), with ROS Indigo. The error is quoted below.
I already discovered this answer: http://answers.ros.org/question/224904/cv_bridge-install-error-on-rpi-rosindigo/ However, the solution doesn't help me as it requires modifying the codebase to only work with little endian data, which I cannot guarantee. Digging through the source, it appears that cv_bridge includes the necessary boost::endian::conversion files within its source code, hence it should not require boost 1.58+ to be installed system-wide. However, compiling this included boost library creates this error.
Does anyone have any ideas how to debug this error or how to fix it? Thanks in advance!
In file included from /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:36:0: /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:26:3: warning: scoped enums only available with -std=c++11 or -std=gnu++11 [enabled by default] /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:329:72: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:328:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversible> class boost::endian::detail::value_converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:331:78: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:328:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversible> class boost::endian::detail::value_converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:333:75: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:328:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversible> class boost::endian::detail::value_converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:335:75: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:328:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversible> class boost::endian::detail::value_converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:411:65: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:410:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversibleInplace> class boost::endian::detail::converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:413:71: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:410:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversibleInplace> class boost::endian::detail::converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:415:68: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:410:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversibleInplace> class boost::endian::detail::converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:417:68: error: wrong number of template arguments (1, should be 3) /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/boost/endian/conversion.hpp:410:13: error: provided for ‘template<boost::endian::order From, boost::endian::order To, class EndianReversibleInplace> class boost::endian::detail::converter’ /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp: In function ‘cv::Mat cv_bridge::matFromImage(const Image&)’: /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:274:23: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:274:55: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:275:23: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:275:55: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp: In member function ‘void cv_bridge::CvImage::toImageMsg(sensor_msgs::Image&) const’: /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:369:44: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:369:76: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp: In function ‘cv_bridge::CvImageConstPtr cv_bridge::toCvShare(const Image&, const boost::shared_ptr&, const string&)’: /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:419:23: error: ‘boost::endian::order’ is not a class or namespace /home/px4/indigo_catkin_ws/src/vision_opencv/cv_bridge/src/cv_bridge.cpp:419:55: error: ‘boost::endian::order’ is not a class or namespace make[2]: *** [src/CMakeFiles/cv_bridge.dir/cv_bridge.cpp.o] Error 1 make[1]: *** [src/CMakeFiles/cv_bridge.dir/all] Error 2 make: *** [all] Error 2
Originally posted by powerstorm42 on ROS Answers with karma: 11 on 2017-01-03
Comment by ahendrix on 2017-01-03:
ROS depends on boost, so by including a second version of boost within cv_bridge you'll end up with two versions of boost on the include path, and then the order of include flags will determine which version ends up actually being included, in addition to creating symbol conflicts at link time
In the end I was able to get cv_bridge to compile by upgrading Ubilinux from Debian 7 Wheezy to 8 Jessie. It is possible that libboost1.49-dev included in Wheezy was too old for cv_bridge, and Jessie comes with libboost1.55-dev. Boost 1.53 is also the minimum version required for ROS Indigo: http://www.ros.org/reps/rep-0003.html (note that the official installation instructions for Indigo on Debian Wheezy don't mention the libboost-dev library being too old). For anyone else experiencing similar issues with ROS on Edison, there are some updated install scripts and instructions for Indigo and Kinetic available here: https://github.com/pennaerial/ros-setups
Originally posted by powerstorm42 with karma: 11 on 2017-01-04
