20160102 I am installing Kinetic on a raspberry pi 2 Jessie
I think I'm getting errors on connection.cpp and subscriber.cpp?
My directory structure is this: /home/dwulkan/robot/ros/catkin_ws
+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ This is where I was in the installation when the error occurred +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3.3 Building the catkin Workspace Once you have completed downloading the packages and have resolved the dependencies, you are ready to build the catkin packages.
Invoke catkin_make_isolated:
$ sudo ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release --install-space /opt/ros/kinetic
+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ The error message(s) +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
[ 33%] Building CXX object CMakeFiles/roscpp.dir/src/libros/network.cpp.o [ 36%] Building CXX object CMakeFiles/roscpp.dir/src/libros/master.cpp.o [ 36%] Building CXX object CMakeFiles/roscpp.dir/src/libros/subscriber.cpp.o [ 38%] Building CXX object CMakeFiles/roscpp.dir/src/libros/common.cpp.o [ 39%] Building CXX object CMakeFiles/roscpp.dir/src/libros/publisher_link.cpp.o [ 40%] Building CXX object CMakeFiles/roscpp.dir/src/libros/service_publication.cpp.o [ 42%] Building CXX object CMakeFiles/roscpp.dir/src/libros/connection.cpp.o c++: internal compiler error: Killed (program cc1plus) Please submit a full bug report, with preprocessed source if appropriate. See file:///usr/share/doc/gcc-4.9/README.Bugs for instructions. CMakeFiles/roscpp.dir/build.make:110: recipe for target 'CMakeFiles/roscpp.dir/src/libros/subscriber.cpp.o' failed make[2]: *** [CMakeFiles/roscpp.dir/src/libros/subscriber.cpp.o] Error 4 make[2]: *** Waiting for unfinished jobs.... c++: internal compiler error: Killed (program cc1plus) Please submit a full bug report, with preprocessed source if appropriate. See file:///usr/share/doc/gcc-4.9/README.Bugs for instructions. CMakeFiles/roscpp.dir/build.make:158: recipe for target 'CMakeFiles/roscpp.dir/src/libros/publisher_link.cpp.o' failed make[2]: *** [CMakeFiles/roscpp.dir/src/libros/publisher_link.cpp.o] Error 4
+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ connection.cpp
  • Software License Agreement (BSD License)
  • Copyright (c) 2008, Willow Garage, Inc.
  • All rights reserved.
  • Redistribution and use in source and binary forms, with or without
  • modification, are permitted provided that the following conditions
  • are met:
    • Redistributions of source code must retain the above copyright
  • notice, this list of conditions and the following disclaimer.
    • Redistributions in binary form must reproduce the above
  • copyright notice, this list of conditions and the following
  • disclaimer in the documentation and/or other materials provided
  • with the distribution.
    • Neither the name of Willow Garage, Inc. nor the names of its
  • contributors may be used to endorse or promote products derived
  • from this software without specific prior written permission.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
  • "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
  • LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
  • FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
  • COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  • INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
  • BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  • LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  • CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
  • LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
  • ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
  • POSSIBILITY OF SUCH DAMAGE. */
#include "ros/connection.h" #include "ros/transport/transport.h" #include "ros/file_log.h"
#include <ros/assert.h>
#include <boost/shared_array.hpp> #include <boost/bind.hpp>
namespace ros {
Connection::Connection() : is_server_(false) , dropped_(false) , read_filled_(0) , read_size_(0) , reading_(false) , has_read_callback_(0) , write_sent_(0) , write_size_(0) , writing_(false) , has_write_callback_(0) , sending_header_error_(false) { }
Connection::~Connection() { ROS_DEBUG_NAMED("superdebug", "Connection destructing, dropped=%s", dropped_ ? "true" : "false");
drop(Destructing); }
void Connection::initialize(const TransportPtr& transport, bool is_server, const HeaderReceivedFunc& header_func) { ROS_ASSERT(transport);
transport_ = transport; header_func_ = header_func; is_server_ = is_server;
transport_->setReadCallback(boost::bind(&Connection::onReadable, this, 1)); transport->setWriteCallback(boost::bind(&Connection::onWriteable, this, 1)); transport->setDisconnectCallback(boost::bind(&Connection::onDisconnect, this, _1));
if (header_func) { read(4, boost::bind(&Connection::onHeaderLengthRead, this, _1, _2, _3, _4)); } }
boost::signals2::connection Connection::addDropListener(const DropFunc& slot) { boost::recursive_mutex::scoped_lock lock(drop_mutex_); return drop_signal_.connect(slot); }
void Connection::removeDropListener(const boost::signals2::connection& c) { boost::recursive_mutex::scoped_lock lock(drop_mutex_); c.disconnect(); }
void Connection::onReadable(const TransportPtr& transport) { (void)transport; ROS_ASSERT(transport == transport_);
readTransport(); }
void Connection::readTransport() { boost::recursive_mutex::scoped_try_lock lock(read_mutex_);
if (!lock.owns_lock() || dropped_ || reading_) { return; }
reading_ = true;
while (!dropped_ && has_read_callback_) { ROS_ASSERT(read_buffer_); uint32_t to_read = read_size_ - read_filled_; if (to_read > 0) { int32_t bytes_read = transport_->read(read_buffer_.get() + read_filled_, to_read); ROS_DEBUG_NAMED("superdebug", "Connection read %d bytes", bytes_read); if (dropped_) { return; } else if (bytes_read < 0) { // Bad read, throw away results and report error ReadFinishedFunc callback; callback = read_callback_; read_callback_.clear(); read_buffer_.reset(); uint32_t size = read_size_; read_size_ = 0; read_filled_ = 0; has_read_callback_ = 0;
    if (callback)
      callback(shared_from_this(), read_buffer_, size, false);
    break;
  read_filled_ += bytes_read;
ROS_ASSERT((int32_t)read_size_ >= 0);
ROS_ASSERT((int32_t)read_filled_ >= 0);
ROS_ASSERT_MSG(read_filled_ <= read_size_, "read_filled_ = %d, read_size_ = %d", read_filled_, read_size_);
if (read_filled_ == read_size_ && !dropped_)
  uint32_t size;
  boost::shared_array<uint8_t> buffer;
  ROS_ASSERT(has_read_callback_);
  // store off the read info in case another read() call is made from within the callback
  size = read_size_;
  buffer = read_buffer_;
  read_size_ = 0;
  read_filled_ = 0;
  ROS_DEBUG_NAMED("superdebug", "Calling read callback");
  callback(shared_from_this(), buffer, size, true);
else
  break;
if (!has_read_callback_) { transport_->disableRead(); }
reading_ = false; }
void Connection::writeTransport() { boost::recursive_mutex::scoped_try_lock lock(write_mutex_);
if (!lock.owns_lock() || dropped_ || writing_) { return; }
writing_ = true; bool can_write_more = true;
while (has_write_callback_ && can_write_more && !dropped_) { uint32_t to_write = write_size_ - write_sent_; ROS_DEBUG_NAMED("superdebug", "Connection writing %d bytes", to_write); int32_t bytes_sent = transport_->write(write_buffer_.get() + write_sent_, to_write); ROS_DEBUG_NAMED("superdebug", "Connection wrote %d bytes", bytes_sent);
if (bytes_sent < 0)
  writing_ = false;
  return;
write_sent_ += bytes_sent;
if (bytes_sent < (int)write_size_ - (int)write_sent_)
  can_write_more = false;
if (write_sent_ == write_size_ && !dropped_)
  WriteFinishedFunc callback;
    boost::mutex::scoped_lock lock(write_callback_mutex_);
    ROS_ASSERT(has_write_callback_);
    // Store off a copy of the callback in case another write() call happens in it
    callback = write_callback_;
    write_callback_ = WriteFinishedFunc();
    write_buffer_ = boost::shared_array<uint8_t>();
    write_sent_ = 0;
    write_size_ = 0;
    has_write_callback_ = 0;
  ROS_DEBUG_NAMED("superdebug", "Calling write callback");
  callback(shared_from_this());
{ boost::mutex::scoped_lock lock(write_callback_mutex_); if (!has_write_callback_) { transport_->disableWrite(); } }
writing_ = false; }
void Connection::onWriteable(const TransportPtr& transport) { (void)transport; ROS_ASSERT(transport == transport_);
writeTransport(); }
void Connection::read(uint32_t size, const ReadFinishedFunc& callback) { if (dropped_ || sending_header_error_) { return; }
{ boost::recursive_mutex::scoped_lock lock(read_mutex_);
ROS_ASSERT(!read_callback_);
read_callback_ = callback;
read_buffer_ = boost::shared_array<uint8_t>(new uint8_t[size]);
read_size_ = size;
read_filled_ = 0;
has_read_callback_ = 1;
transport_->enableRead();
// read immediately if possible readTransport(); }
void Connection::write(const boost::shared_array<uint8_t>& buffer, uint32_t size, const WriteFinishedFunc& callback, bool immediate) { if (dropped_ || sending_header_error_) { return; }
ROS_ASSERT(!write_callback_);
write_callback_ = callback;
write_buffer_ = buffer;
write_size_ = size;
write_sent_ = 0;
has_write_callback_ = 1;
transport_->enableWrite();
if (immediate) { // write immediately if possible writeTransport(); } }
void Connection::onDisconnect(const TransportPtr& transport) { (void)transport; ROS_ASSERT(transport == transport_);
drop(TransportDisconnect); }
void Connection::drop(DropReason reason) { ROSCPP_LOG_DEBUG("Connection::drop(%u)", reason); bool did_drop = false; { boost::recursive_mutex::scoped_lock lock(drop_mutex_); if (!dropped_) { dropped_ = true; did_drop = true; } }
if (did_drop) { drop_signal_(shared_from_this(), reason); transport_->close(); } }
bool Connection::isDropped() { boost::recursive_mutex::scoped_lock lock(drop_mutex_); return dropped_; }
void Connection::writeHeader(const M_string& key_vals, const WriteFinishedFunc& finished_callback) { ROS_ASSERT(!header_written_callback_); header_written_callback_ = finished_callback;
if (!transport_->requiresHeader()) { onHeaderWritten(shared_from_this()); return; }
boost::shared_array<uint8_t> buffer; uint32_t len; Header::write(key_vals, buffer, len);
uint32_t msg_len = len + 4; boost::shared_array<uint8_t> full_msg(new uint8_t[msg_len]); memcpy(full_msg.get() + 4, buffer.get(), len); ((uint32_t)full_msg.get()) = len;
write(full_msg, msg_len, boost::bind(&Connection::onHeaderWritten, this, _1), false); }
void Connection::sendHeaderError(const std::string& error_msg) { M_string m; m["error"] = error_msg;
writeHeader(m, boost::bind(&Connection::onErrorHeaderWritten, this, 1)); sending_header_error = true; }
void Connection::onHeaderLengthRead(const ConnectionPtr& conn, const boost::shared_array<uint8_t>& buffer, uint32_t size, bool success) { (void)size; ROS_ASSERT(conn.get() == this); ROS_ASSERT(size == 4);
if (!success) return;
uint32_t len = ((uint32_t)buffer.get());
if (len > 1000000000) { ROS_ERROR("a header of over a gigabyte was "
"predicted in tcpros. that seems highly "
"unlikely, so I'll assume protocol "
"synchronization is lost."); conn->drop(HeaderError); }
read(len, boost::bind(&Connection::onHeaderRead, this, _1, _2, _3, _4)); }
void Connection::onHeaderRead(const ConnectionPtr& conn, const boost::shared_array<uint8_t>& buffer, uint32_t size, bool success) { ROS_ASSERT(conn.get() == this);
std::string error_msg; if (!header_.parse(buffer, size, error_msg)) { drop(HeaderError); } else { std::string error_val; if (header_.getValue("error", error_val)) { ROSCPP_LOG_DEBUG("Received error message in header for connection to [%s]: [%s]", transport_->getTransportInfo().c_str(), error_val.c_str()); drop(HeaderError); } else { ROS_ASSERT(header_func_);
  transport_->parseHeader(header_);
  header_func_(conn, header_);
void Connection::onHeaderWritten(const ConnectionPtr& conn) { ROS_ASSERT(conn.get() == this); ROS_ASSERT(header_written_callback_);
header_written_callback_(conn); header_written_callback_ = WriteFinishedFunc(); }
void Connection::onErrorHeaderWritten(const ConnectionPtr& conn) { (void)conn; drop(HeaderError); }
void Connection::setHeaderReceivedCallback(const HeaderReceivedFunc& func) { header_func_ = func;
if (transport_->requiresHeader()) read(4, boost::bind(&Connection::onHeaderLengthRead, this, _1, _2, _3, _4)); }
std::string Connection::getCallerId() { std::string callerid; if (header_.getValue("callerid", callerid)) { return callerid; }
return std::string("unknown"); }
std::string Connection::getRemoteString() { std::stringstream ss; ss << "callerid=[" << getCallerId() << "] address=[" << transport_->getTransportInfo() << "]"; return ss.str(); }
++++++++++++++++++++++++++++++++++++++ subscriber.cpp
  • Copyright (C) 2009, Willow Garage, Inc.
  • modification, are permitted provided that the following conditions are met:
    • Redistributions of source code must retain the above copyright notice,
  • this list of conditions and the following disclaimer.
    • Redistributions in binary form must reproduce the above copyright
  • notice, this list of conditions and the following disclaimer in the
  • documentation and/or other materials provided with the distribution.
    • Neither the names of Stanford University or Willow Garage, Inc. nor the names of its
  • contributors may be used to endorse or promote products derived from
  • this software without specific prior written permission.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  • AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  • IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
  • ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
  • LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
  • CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
  • SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
  • INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
  • CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  • ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
#include "ros/subscriber.h" #include "ros/node_handle.h" #include "ros/topic_manager.h"
namespace ros {
Subscriber::Impl::Impl() : unsubscribed_(false) { }
Subscriber::Impl::~Impl() { ROS_DEBUG("Subscriber on '%s' deregistering callbacks.", topic_.c_str()); unsubscribe(); }
bool Subscriber::Impl::isValid() const { return !unsubscribed_; }
void Subscriber::Impl::unsubscribe() { if (!unsubscribed_) { unsubscribed_ = true; TopicManager::instance()->unsubscribe(topic_, helper_); node_handle_.reset(); helper_.reset(); } }
Subscriber::Subscriber(const std::string& topic, const NodeHandle& node_handle, const SubscriptionCallbackHelperPtr& helper) : impl_(boost::make_shared()) { impl_->topic_ = topic; impl_->node_handle_ = boost::make_shared(node_handle); impl_->helper_ = helper; }
Subscriber::Subscriber(const Subscriber& rhs) { impl_ = rhs.impl_; }
Subscriber::~Subscriber() { }
void Subscriber::shutdown() { if (impl_) { impl_->unsubscribe(); } }
std::string Subscriber::getTopic() const { if (impl_) { return impl_->topic_; }
return std::string();
uint32_t Subscriber::getNumPublishers() const { if (impl_ && impl_->isValid()) { return TopicManager::instance()->getNumPublishers(impl_->topic_); }
return 0;
} // namespace ros
Originally posted by DaveWulkan on ROS Answers with karma: 1 on 2017-01-02
Comment by suforeman on 2017-01-02:
(converted to an answer)
May I suggest an alternate solution.
You can download and install an image of Ubuntu 16.04 for the RPi 2 & 3.I'd recommend the server version with no GUI).
Then you can use apt-get to install ROS and packages.
https://ubuntu-mate.org/blog/ubuntu-mate-xenial-raspberry-pi/
Originally posted by suforeman with karma: 300 on 2017-01-03
Comment by ahendrix on 2017-01-03:
Seconded; if you're willing to install Ubuntu, the installation through apt-get is much faster and more reliable.
