this is my package: https://github.com/azhar92/GUI-for-AV.git
When I open rqt and try to open the plugin from the drop-down menu using the following steps
cd ~/catkin_ws
catkin_make
source ~/catkin_ws/devel/setup.bash
rqt --force-discover
I can see the name of my package when in the rqt gui, but when i click it,
I get the following error in the terminal output:
[ERROR] [1482121854.496133919]: Failed to load nodelet [rqt_test1/MyPlugin_1] of type [rqt_test1/MyPlugin]: MultiLibraryClassLoader: Could not create object of class type rqt_test1::MyPlugin as no factory exists for it. Make sure that the library exists and was explicitly loaded through MultiLibraryClassLoader::loadLibrary()
RosPluginlibPluginProvider::load_explicit_type(rqt_test1/MyPlugin) failed creating instance
PluginManager._load_plugin() could not load plugin "rqt_test1/MyPlugin": RosPluginlibPluginProvider.load() could not load plugin "rqt_test1/MyPlugin"
i think it has to do with the registration of the plugin. any form of guidance will be helpful. Thank you.
Plugin.xml : https://github.com/azhar92/GUI-for-AV/blob/master/plugin.xml
Code:
<library path="lib/librqt_test1">
 <class name="rqt_test1/MyPlugin" type="rqt_test1::MyPlugin" base_class_type="rqt_gui_cpp::Plugin">
   <description>
4 buttons to switch between 4 different modes.
</description>
 <qtgui>
  <group>
   <label>Visualization</label>
    <statustip>Plugins related to visualization.</statustip>
  </group>
 <label>test1</label>
 <statustip>4 buttons to switch between 4 different modes.</statustip>
 </qtgui>
</class>
</library>
Originally posted by Azhar on ROS Answers with karma: 100 on 2016-12-19
Comment by gvdhoorn on 2016-12-19:\
If you feel that is the case, then please include at least a snippet of code where you show how you implemented that bit.
This question will become worthless otherwise if/when your repository is removed/deleted/changed.
Comment by Azhar on 2016-12-19:
I have edit the question. let me know if there are any other things you need. Thank you!
i have not changed my repository!
So where is the code where you actually register your plugin (or really: export it / make it known to class loader)? Please include that in your question.
Comment by AndyZe on 2016-12-19:
From a quick glance, I don't see anything to cause that error. But you can delete this from CMakeLists:
install(PROGRAMS scripts/${PROJECT_NAME}/gauge_script.py
  DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
Comment by Azhar on 2016-12-20:
@AndyZelenak, i tried it but it doesn't help. same error ;(
Compare your main.cpp to my_plugin.cpp. You don't have this line at the bottom:
PLUGINLIB_DECLARE_CLASS(rqt_gauges, MyPlugin, rqt_gauges::MyPlugin, rqt_gui_cpp::Plugin)
And you're missing this function (which seems important):
void MyPlugin::initPlugin(qt_gui_cpp::PluginContext& context)
So go back and spend some time fixing those obvious issues. I think we would be more motivated to help if you upvoted good answers, too.
Originally posted by AndyZe with karma: 2331 on 2016-12-21
