I'm using MoveIt! to generate motion plans for a robot arm. Have it working just fine using the defined move_group for my arm. My question is, when executing a plan with group.go(wait=False), what is the correct way to check on the status of the execution of the path?
The return of group.go(wait=False) is a boolean so that doesn't do me any good, and the group, and robot objects do not seem to have anything indicating a plan is being executed.
Originally posted by oars on ROS Answers with karma: 48 on 2016-12-13
Comment by JoshMarino on 2016-12-14:
Should be able to check the status of the controller or from joint states.
Hi Oars,
There is no way to check for the status of group.go(wait=False) using the standard moveit_commande API calls. However, under the hood, the moveit_commander makes a call to the moveit_msgs/MoveGroup Action. The difference between async and non-async is that when you tell moveit_commander to wait, it monitors the output of the MoveGroup Action state and only returns control to the caller when the action has either succeeded or failed.
To see how that works: the code that does so can be found here.
To get the relevant information from the action server you can subscribe to the /move_group/status/ topic, which publishes a actionlib_msgs/GoalStatusArray that "stores the statuses for goals that are currently being tracked". An alternative would be the /move_group/feedback/ topic, which also contains information on what the action server is doing.
I'd advise you to rostopic echo both topics to see what messages are being published so you can decide which is easier to use.
Originally posted by rbbg with karma: 1823 on 2016-12-14
Post score: 11
Comment by oars on 2016-12-14:
Awesome! Thanks for the detailed answer. Really appreciate it. This gives me all I need moving forward.
