Installing indigo arm on jetson tegra tk1 using these instructions: (http://wiki.ros.org/indigo/Installation/Ubuntu).
I am at 'rosdep update' and it fails sporadically at different points.
I have tried reinstalling indigo. I can resolve DNS/IP fine, and almost every file has both succeeded or failed. I have tried to purge, update, reinstall rosdep (yes rosdep --version and apt-cache policy are the same).
Here is an example 2 runs:
RUN 1:
Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 3.10.40-gdacac96 armv7l)
 * Documentation:  https://help.ubuntu.com/
Last login: Thu Dec  8 00:15:42 2016
ubuntu@tegra-ubuntu:~$ rosdep update
reading in sources list data from /etc/ros/rosdep/sources.list.d
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml
Hit https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml
ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml]:
        Failed to download target platform data for gbpdistro:
        <urlopen error timed out>
Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml
ERROR: error loading sources list:
        <urlopen error <urlopen error [Errno -2] Name or service not known> (https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml)>
RUN 2 (30 seconds later):
Hit https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml
Add distro "groovy"
Add distro "hydro"
Add distro "indigo"
Add distro "jade"
        <urlopen error <urlopen error [Errno -2] Name or service not known> (https://raw.githubusercontent.com/ros/rosdistro/master/jade/distribution.yaml)>
I did this as an example while I was running this and it was the furthest it has ever gotten.
Should I just wait for sunny days in the future where I will get lucky and everything will work? I would also like to note that the views on forum items with "rosdep update" all have >300 views so I am seeing an issue with this delivery method.
I also successfully dual-booted ubuntu 14.04 and installed indigo on a Mac last night at ~2 am so maybe I will wait for 2 am to come around.
Originally posted by anonymous28754 on ROS Answers with karma: 1 on 2016-12-07
Github had a fairly substantial outage today that may have contributed to this: https://status.github.com/messages/2016-12-07
Originally posted by ahendrix with karma: 47576 on 2016-12-08
