I would like to test a library that require a sensor _msgs/LaserScan topic. I found this question http://answers.ros.org/question/9450/how-to-setup-pointcloud_to_laserscan/ but I am pretty new to ROS and I have a lot of difficulties in adapting this solution to my case. Could you help me with this?
Originally posted by ESeNonFossiIo on ROS Answers with karma: 1 on 2016-12-07
Comment by McMurdo on 2016-12-07:
What's the problem in your case? What exactly is the error when you run that launch file?
Comment by ESeNonFossiIo on 2016-12-07:
I do not know how to write a launch file for the VLP16. I got two default launch files but they are supposed to work with Kinect.
There is Velodyne specific software:
https://github.com/ros-drivers/velodyne/pull/110
http://wiki.ros.org/but_velodyne_proc#Laserscan_Node
Edit: Added velodyne_laserscan pull request
Originally posted by kmhallen with karma: 1416 on 2016-12-07
I couldn't compile it on my laptop. I got:
but_calibration_camera_velodyne/Calibration.h:53:24: error: ‘isnan’ was not declared in this scope
 return !isnan(value);
Comment by ESeNonFossiIo on 2016-12-09:
Using your branch it seems working. I see /scan and the output is ok.
