Hello everybody,
i'm using Ubuntu 14.04 LTS and ROS Indigo
i'm trying to launch tutorial 3 for nav2d package. but it seems that there's error in the mapper.
all what i did is first i launched the toturial3
roslaunch nav2d_tutorials tutorial3.launch
then in a separate terminal i call these services as instructed since i don't have a joystick.
rosservice call /StartMapping 3
rosservice call /StartExploration 2
here is the screen shots of the errors.
image description
here is my rqt_graph
image description
here is my tf view_frames
image description
frames.gv
Thank you in advance.
Originally posted by alhouty808 on ROS Answers with karma: 1 on 2016-12-07
Comment by Sebastian Kasperski on 2016-12-07:
Looks like the mapper dies right on startup. Can you please send the log file that is mentioned in the error message? And please check your installed boost-version. It should be 1.54.0.1 from Ubuntu 14.04. Have you ever installed another boost version then the one from Ubuntu repositories?
PS: Do you have installed nav2d as binary package or is it a source build?
Comment by alhouty808 on 2016-12-07:
as a binary package. here is log file
my boost-version is : 1.54.0.1ubuntu1 i haven't installed another boost version ever.
Thank you for your reply. I really appreciate your time.
I hope you didn't forget me here is my log file log file
Regularly update all your ROS packages to avoid conflicts between packages that have different release versions.
Originally posted by Sebastian Kasperski with karma: 1658 on 2016-12-09
