Hi,
I am just learning about ros_control and saw the diff_drive_controller plugin. I am wondering how I would correctly integrate some PID control in with this? Would I have to have the write() function in my RobotHW publishing to a PID node, which then publishes to another hardware interface to send it to the robot? It seems a bit long-winded and somewhat breaks the ros_control model?
I'd appreciate your guidance!
Thanks.
Originally posted by epsilonjon on ROS Answers with karma: 123 on 2016-12-05
Post score: 4
Sadly ros_control does not do stacked/hierarchical control particularly well. In a perfect world, you'd have diff_drive_controller running together with a velocity controller in the controller manager, passing messages in some standard RT-safe fashion. Your hardware would be exposed as an EffortInterface or similar. Alas, it is not (yet) a perfect world.
You can take a look at how hector_quadrotor's control hierarchy works (stacked position/velocity/attitude controllers, using pointer 'handles' to pass data instead of RT-unsafe pub/sub).
Another alternative is to have your RobotHW class expose the VelocityInterface diff_drive_controller is looking for, and add the PID controller in the RobotHW to transform the velocity command into whatever your hardware ACTUALLY needs. Not as 'modular' as ros_control feels like it should be, but it would work.
PS see control_toolbox package in ros_control for a standard PID implementation.
Originally posted by paulbovbel with karma: 4518 on 2016-12-06
Comment by epsilonjon on 2016-12-09:
Thank you very much for your answer. I will take a look at the hector_quadroter as suggested. It's a coincidence you replied as I was looking at your Jackal repo the other day. Am I correct in thinking that you have no software PID in there? You just use diff_drive_controller without?
Comment by paulbovbel on 2016-12-09:
right, the PID runs on the MCU, talking to diff_drive_controller through ROS pub/sub
