I have a library called grl which integrates control of a KUKA iiwa in C++.
Right now the most reliable mechanism I've found for control is to receive state over FRI, then send state via Java. All the tools necessary to do this are integrated into grl.
While I've been able to receive state over FRI nicely, sending FRI commands so the robot drives reliably has proven more complicated. I'm close to a working implementation and I have a few simple test applications that move a single joint correctly. Once the bugs are worked out it should be very easy to use, and I'm hopeful it will work well. For a specific function controlling FRI see KukaFRIClientDataDriver.cpp.
Unfortunately I've found the direct API KUKA provides to be a bit difficult to use as well, so I'm implementing functions that communicate over the underlying protobuf network messages and UDP.
While this isn't a 100% answer, it is a solution that is 90% of the way to completion.
Update: FRI based control using grl is now working with the Sunrise Connectivity Suite 1.7.
Here is an example of how to use it in the simplest case of KukaFRIClientDataDriverTest.cpp:
// Library includes
#include <string>
#include <ostream>
#include <iostream>
#include <memory>
#include "grl/KukaFRI.hpp"
#include "grl/KukaFriClientData.hpp"
#include <boost/log/trivial.hpp>
#include <cstdlib>
#include <cstring>
#include <iostream>
#include <boost/asio.hpp>
#include <vector>
#include <iostream>
using boost::asio::ip::udp;
#include <chrono>
/// @see https://stackoverflow.com/questions/2808398/easily-measure-elapsed-time
template<typename TimeT = std::chrono::milliseconds>
struct periodic
periodic():start(std::chrono::system_clock::now()){};
template<typename F, typename ...Args>
typename TimeT::rep execution(F func, Args&&... args)
auto duration = std::chrono::duration_cast< TimeT>
(std::chrono::system_clock::now() - start);
auto count = duration.count();
if(count > previous_count) func(std::forward<Args>(args)...);
previous_count = count;
return count;
std::chrono::time_point<std::chrono::system_clock> start;
std::size_t previous_count;
enum { max_length = 1024 };
int main(int argc, char* argv[])
periodic<> callIfMinPeriodPassed;
try
std::string localhost("192.170.10.100");
std::string localport("30200");
std::string remotehost("192.170.10.2");
std::string remoteport("30200");
std::cout << "argc: " << argc << "\n";
if (argc !=5 && argc !=1)
std::cerr << "Usage: " << argv[0] << " <localip> <localport> <remoteip> <remoteport>\n";
return 1;
if(argc ==5){
localhost = std::string(argv[1]);
localport = std::string(argv[2]);
remotehost = std::string(argv[3]);
remoteport = std::string(argv[4]);
std::cout << "using: " << argv[0] << " " << localhost << " " << localport << " " << remotehost << " " << remoteport << "\n";
boost::asio::io_service io_service;
std::shared_ptr<KUKA::FRI::ClientData> friData(std::make_shared<KUKA::FRI::ClientData>(7));
std::chrono::time_point<std::chrono::high_resolution_clock> startTime;
BOOST_VERIFY(friData);
double delta = -0.0001;
/// consider moving joint angles based on time
int joint_to_move = 6;
BOOST_LOG_TRIVIAL(warning) << "WARNING: YOU COULD DAMAGE OR DESTROY YOUR KUKA ROBOT "
<< "if joint angle delta variable is too large with respect to "
<< "the time it takes to go around the loop and change it. "
<< "Current delta (radians/update): " << delta << " Joint to move: " << joint_to_move << "\n";
std::vector<double> ipoJointPos(7,0);
std::vector<double> offsetFromipoJointPos(7,0); // length 7, value 0
std::vector<double> jointStateToCommand(7,0);
grl::robot::arm::KukaFRIClientDataDriver driver(io_service,
std::make_tuple(localhost,localport,remotehost,remoteport,grl::robot::arm::KukaFRIClientDataDriver::run_automatically)
for (std::size_t i = 0;;++i) {
/// use the interpolated joint position from the previous update as the base
if(i!=0 && friData) grl::robot::arm::copy(friData->monitoringMsg,ipoJointPos.begin(),grl::revolute_joint_angle_interpolated_open_chain_state_tag());
/// perform the update step, receiving and sending data to/from the arm
boost::system::error_code send_ec, recv_ec;
std::size_t send_bytes_transferred = 0, recv_bytes_transferred = 0;
bool haveNewData = !driver.update_state(friData, recv_ec, recv_bytes_transferred, send_ec, send_bytes_transferred);
// if data didn't arrive correctly, skip and try again
if(send_ec || recv_ec )
std::cout << "receive error: " << recv_ec << "receive bytes: " << recv_bytes_transferred << " send error: " << send_ec << " send bytes: " << send_bytes_transferred << " iteration: "<< i << "\n";
std::this_thread::sleep_for(std::chrono::milliseconds(1));
continue;
// If we didn't receive anything new that is normal behavior,
// but we can't process the new data so try updating again immediately.
if(!haveNewData)
continue;
/// @todo why is this?
if (grl::robot::arm::get(friData->monitoringMsg,KUKA::FRI::ESessionState()) == KUKA::FRI::COMMANDING_ACTIVE)
#if 1 // disabling this block causes the robot to simply sit in place, which seems to work correctly. Enabling it causes the joint to rotate.
callIfMinPeriodPassed.execution( [&offsetFromipoJointPos,&delta,joint_to_move]()
offsetFromipoJointPos[joint_to_move]+=delta;
// swap directions when a half circle was completed
if (
(offsetFromipoJointPos[joint_to_move] > 0.2 && delta > 0) ||
(offsetFromipoJointPos[joint_to_move] < -0.2 && delta < 0)
delta *=-1;
#endif
KUKA::FRI::ESessionState sessionState = grl::robot::arm::get(friData->monitoringMsg,KUKA::FRI::ESessionState());
// copy current joint position to commanded position
if (sessionState == KUKA::FRI::COMMANDING_WAIT || sessionState == KUKA::FRI::COMMANDING_ACTIVE)
boost::transform ( ipoJointPos, offsetFromipoJointPos, jointStateToCommand.begin(), std::plus<double>());
grl::robot::arm::set(friData->commandMsg, jointStateToCommand, grl::revolute_joint_angle_open_chain_command_tag());
// vector addition between ipoJointPosition and ipoJointPositionOffsets, copying the result into jointStateToCommand
/// @todo should we take the current joint state into consideration?
//BOOST_LOG_TRIVIAL(trace) << "position: " << state.position << " us: " << std::chrono::duration_cast<std::chrono::microseconds>(state.timestamp - startTime).count() << " connectionQuality: " << state.connectionQuality << " operationMode: " << state.operationMode << " sessionState: " << state.sessionState << " driveState: " << state.driveState << " ipoJointPosition: " << state.ipoJointPosition << " ipoJointPositionOffsets: " << state.ipoJointPositionOffsets << "\n";
catch (std::exception& e)
std::cerr << "Exception: " << e.what() << "\n";
return 0;
Here is the Java side of the application:
package friCommunication;
import static com.kuka.roboticsAPI.motionModel.BasicMotions.positionHold;
import static com.kuka.roboticsAPI.motionModel.BasicMotions.ptp;
import java.util.concurrent.TimeUnit;
import java.util.concurrent.TimeoutException;
import com.kuka.connectivity.fri.FRIConfiguration;
import com.kuka.connectivity.fri.FRIJointOverlay;
import com.kuka.connectivity.fri.FRISession;
import com.kuka.roboticsAPI.applicationModel.RoboticsAPIApplication;
import com.kuka.roboticsAPI.controllerModel.Controller;
import com.kuka.roboticsAPI.deviceModel.LBR;
import com.kuka.roboticsAPI.geometricModel.CartDOF;
import com.kuka.roboticsAPI.motionModel.controlModeModel.CartesianImpedanceControlMode;
* Creates a FRI Session.
public class FRIHoldsPosition_Command extends RoboticsAPIApplication
private Controller _lbrController;
private LBR _lbr;
private String _hostName;
@Override
public void initialize()
_lbrController = (Controller) getContext().getControllers().toArray()[0];
_lbr = (LBR) _lbrController.getDevices().toArray()[0];
// *** change next line to the FRIClient's IP address ***
_hostName = "192.170.10.100";
@Override
public void run()
// configure and start FRI session
FRIConfiguration friConfiguration = FRIConfiguration.createRemoteConfiguration(_lbr, _hostName);
friConfiguration.setSendPeriodMilliSec(4);
FRISession friSession = new FRISession(friConfiguration);
FRIJointOverlay motionOverlay = new FRIJointOverlay(friSession);
try {
friSession.await(10, TimeUnit.SECONDS);
} catch (TimeoutException e) {
// TODO Automatisch generierter Erfassungsblock
e.printStackTrace();
friSession.close();
return;
CartesianImpedanceControlMode controlMode = new CartesianImpedanceControlMode();
controlMode.parametrize(CartDOF.X).setStiffness(100.0);
controlMode.parametrize(CartDOF.ALL).setDamping(0.7);
// TODO: remove default start pose
// move to default start pose
_lbr.move(ptp(Math.toRadians(10), Math.toRadians(10), Math.toRadians(10), Math.toRadians(-90), Math.toRadians(10), Math.toRadians(10),Math.toRadians(10)));
// sync move for infinite time with overlay ...
_lbr.move(positionHold(controlMode, -1, TimeUnit.SECONDS).addMotionOverlay(motionOverlay));
//_lbr.moveAsync(ptp(Math.toRadians(-90), .0, .0, Math.toRadians(90), .0, Math.toRadians(-90), .0));
// done
friSession.close();
* main.
* @param args
* args
public static void main(final String[] args)
final FRIHoldsPosition_Command app = new FRIHoldsPosition_Command();
app.runApplication();
