hi . i using solidworks to get urdf file .
in rviz i have this error : Fixed Frame [map] does not exist
how can i fix that error ????
it is my launch file :
 <launch>
  <arg name="model" />
  <param name="robot_description" textfile="$(find wrist)/urdf/wrist.urdf" />
  <param name="use_gui" value="true" />
  <node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
  <node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
 <node name="rviz" pkg="rviz" type="rviz" args="-d $(find wrist)/urdf.rviz" required="true" />
</launch>
it is my urdf file :
    <?xml version="1.0"?>
<robot name="wrist">
  <link name="base_link">
    <inertial>
      <origin xyz="-0.0155222222222222 0.0506514619883041 -0.0711837607475986" rpy="0 0 0" />
      <mass value="0.161357633901786" />
      <inertia ixx="0" ixy="0" ixz="0" iyy="0"  iyz="0" izz="0" />
    </inertial>
    <visual>
      <origin xyz="0 0 0" rpy="0 0 0" />
      <geometry>
        <mesh filename="package://wrist/meshes/base_link.stl" />
      </geometry>
      <material  name="">
        <color  rgba="0.941176470588235 0.674509803921569 0.117647058823529 1" />
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <link name="m2_1">
    <inertial>
      <origin xyz="1.73472347597681E-18 3.46944695195361E-18 -0.0748894348894349" rpy="0 0 0" />
      <mass value="0.0767176926006627" />
    </inertial>
    <visual>
      <geometry>
        <mesh  filename="package://wrist/meshes/m2_1.stl" />
      </geometry>
      <material  name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="m2_1"  type="continuous">
    <origin xyz="-0.0155222222222222 0.0225000000000004 0.0416514619883041" rpy="3.14159265358979 0 0" />
    <parent link="base_link" />
    <child link="m2_1" />
    <axis xyz="0 0 -1" />
  </joint>
  <link name="4_1">
    <inertial>
      <origin xyz="5.20417042793042E-18 1.38777878078145E-17 0.0075" rpy="0 0 0" />
      <mass value="0.192949779317265" />
    </inertial>
    <visual>
      <geometry>
        <mesh filename="package://wrist/meshes/4_1.stl" />
      </geometry>
      <material name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="4_1" type="fixed">
    <origin xyz="-0.0155222222222222 0.00750000000000036 0.0506514619883041" rpy="1.5707963267949 0 0" />
    <child link="4_1" />
    <axis xyz="0 0 0" />
  </joint>
  <link name="m1_1">
    <inertial>
      <origin xyz="6.93889390390723E-18 0 0.0444256539427829" rpy="0 0 0" />
      <mass value="0.0916588444916701" />
    </inertial>
    <visual>
      <geometry>
        <mesh filename="package://wrist/meshes/m1_1.stl" />
      </geometry>
      <material name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="m1_1" type="fixed">
    <origin xyz="-0.071 0 0" rpy="-3.14159265358979 0 -1.5707963267949" />
    <parent link="4_1" />
    <child link="m1_1" />
  </joint>
  <link name="m1_2">
    <inertial>
      <origin xyz="0 1.38777878078145E-17 0.0444256539427829" rpy="0 0 0" />
      <mass value="0.0916588444916702" />
    </inertial>
    <visual>
      <geometry>
        <mesh filename="package://wrist/meshes/m1_2.stl" />
      </geometry>
      <material  name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="m1_2" type="fixed">
    <origin xyz="0.071 0 0" rpy="-3.14159265358979 0 -1.5707963267949" />
    <child link="m1_2" />
  </joint>
  <link name="5_1">
    <inertial>
      <origin xyz="-6.93889390390723E-18 0.0055562404711535 0.00849999999999999"  rpy="0 0 0" />
      <mass value="0.0736873670600793" />
    </inertial>
    <visual>
      <geometry>
        <mesh filename="package://wrist/meshes/5_1.stl" />
      </geometry>
      <material name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="5_1" type="fixed">
    <origin xyz="-0.04 0 0.052" rpy="-1.5707963267949 0 1.5707963267949" />
    <child link="5_1" />
  </joint>
  <link name="5_2">
    <inertial>
      <origin xyz="-6.93889390390723E-18 0.00555624047115352 0.00850000000000001" rpy="0 0 0" />
      <mass value="0.0736873670600792" />
    </inertial>
    <visual>
      <geometry>
        <mesh filename="package://wrist/meshes/5_2.stl" />
      </geometry>
      <material name="">
      </material>
    </visual>
    <collision>
      <geometry>
      </geometry>
    </collision>
  </link>
  <joint name="5_2" type="fixed">
    <origin xyz="0.057 0 0.052" rpy="-1.5707963267949 0 1.5707963267949" />
    <child link="5_2" />
  </joint>
</robot>
how can i fix that error ???? enter code here
Originally posted by zakizadeh on ROS Answers with karma: 217 on 2016-11-30
If you just load the robot, why should RVIZ know where in the map your robot is located? So either publish or define this transformation or just set the fixed frame to "base_link".
Originally posted by NEngelhard with karma: 3519 on 2016-11-30
