I'm making a differential-drive rover with wheel encoders and planar LIDAR, but at the moment no other sensors. I understand why it's useful to have separate map and odom frames--if my wheel odometry was perfect, the transform between the two would be zero, but it's not, so mapping (gmapping at the moment) is needed to find ithe correcting transform. I've implemented a publisher of both nav_msgs.msg.Odometry as topic /odom and tf.TransformBroadcaster as a transform between odom and base_link, according to this tutorial.
However, it doesn't seem that the odom -> base_link transformation provides any information that isn't already present in my /odom topic. Are there other cases in which these would be different, and I'm just not very imaginative? Is the separate existence of the tf just for the (perhaps significant) convenience of having a homogeneous way to transform between odom and map frames? In that case, maybe it would be possible not to publish the /odom topic, since the only extra thing it has is velocities, which I just approximate as the difference from the last message over time increment.
FWIW, my code is here, and in particular this script contains the publisher of both the /odom topic and the broadcaster of the odom -> base_link transformation. I might later solicit comments on the larger project, but at the moment it's a bit disorganized because of a relatively recent jettisoning of Arduino as a bridge to hardware.
Originally posted by tsbertalan on ROS Answers with karma: 63 on 2016-11-24
http://wiki.ros.org/navigation/Tutorials/RobotSetup/Odom says that tf doesn't provide velocity so the navigation stack also wants the Odometry message. tf does provide a lookupTwist function but it either is averaging the velocity over a time period or computing velocity from the last two position updates- the averaging could have a lot of latency or smooth over short duration velocities of interest, and only using the last updates could be noisy. So neither method can recover the instantaneous velocity of the odom message. http://answers.ros.org/question/12894/calculating-velocity-from-tf/
It doesn't mention it but the Odom message also has position and velocity uncertainty information in the pose and twist covariance matrices- it is said to be optional but but a pose filtering scheme would make use of that when fusing odometry with imu or other sensor data. (There is an unmaintained tf version that propagates uncertainty http://wiki.ros.org/uncertain_tf , it would be great if this was revived in the future, and then later support multiple tf parents as well...)
If you have no current or potential subscribers to /odom in your project (doesn't gmapping want it or is it using only sensors?) then it could be eliminated, or made optional (Maybe someone else will want to hook your robot up to the nav stack- and does it really cost you much resources to keep publishing it?).
Originally posted by lucasw with karma: 8729 on 2016-11-25
Post score: 4
Comment by tsbertalan on 2016-11-25:
I see. In that case, maybe I should change the way I report vx, vy, vtheta. At the moment, they're indistinguishable from what you might get from tf, but I it might be useful to get the full noisy signal from within my encoder interrupt functions.
Comment by Karthikey97 on 2017-12-01:
So in that case, is the being sent over the tf broadcaster redundant. I'm saying this as the the nav_msgs/odometry seems to have all the required information (velocity and the pose of the robot with covariance in the odom frame).
