Hello!
I use MoveIt! to control a Kuka Youbot arm in Rviz. Apparently i used the computecartesianpath() to move the arm from point A to B. Afterwards i wanted to display the trajetory from A -> B and tried to use the Trajectory Addon in Rviz but it did not work. Do u have any ideas how i can, at least, prove that the youbot operates in a straight line? At least i know, that the computed cartesian path has 144 points and my terminal shows any jointangle for each point when i display the trajectory.
Edit: Hey!
Thanks for your fast answer Dave, that helped me a lot. Currently i try to implement the rviz plugin in my simulation model. I tried to use the computecartesianpath()-function in MoveIt! and wanted to use the publishpath-function of rviz_visual_tool afterwards to generate the path:
namespace rvt = rviz_visual_tools;
rviz_visual_tools::RvizVisualTools visual_tools("odom_combined");
double fraction = group.computeCartesianPath(waypoints, 0.01, 0.0, trajectory);
visual_tools.deleteAllMarkers();
visual_tools.publishPath(waypoints, rvt::LIME_GREEN, rvt::LARGE);
for (std::size_t i=0; i<waypoints.size(); ++i)
     visual_tools.publishAxisLabeled(waypoints[i], "pt" + std::to_string(i), rvt::SMALL);
visual_tools.trigger();
visual_tools.prompt("next step");
When i try to compile this, i get: error: no matching function for call to "rviz_visual_tools::RvizVisualTools::publishPath(....)
Can u help me to find a solution, please?
Originally posted by mutu on ROS Answers with karma: 25 on 2016-11-17
Comment by gvdhoorn on 2016-11-22:
@mutu: please don't post answers unless you are actually answering your own question. ROS Answers works a little different from a regular forum: update your question if you have more information, or use comments under answers to interact with other users.
Thanks.
You want to see lines traced for the end effector location, like in this video? https://www.youtube.com/watch?v=4FSmZRQh37Q
If so see this tutorial (not merged in yet): https://github.com/ros-planning/moveit_tutorials/pull/45
Originally posted by Dave Coleman with karma: 1396 on 2016-11-17
