Hello ROS users!
I'm working with tf and I've a few questions about the API.
I am defining frames such that Yaw is applied around Z, followed by Pitch around the new Y and then Roll around new X.
Consider a transform from base_link --> camera_frame
. Assuming I only have constant rotation between the frames (zero translation), here's how I create the transform:
//Fixed transform values
double roll, pitch, yaw;
yaw = DEGREES_TO_RADIANS(90); // 90 degrees around Z
pitch = DEGREES_TO_RADIANS(0); // 0 degrees around new Y
roll = DEGREES_TO_RADIANS(-90); // -90 degrees around new X
//Create Quaternion from Euler angles
tf::Quaternion quat;
quat.setRPY(roll, pitch, yaw);
//quat.setEuler(pitch, roll, -yaw); //
//Set rotations
geometry_msgs::TransformStamped bLink_to_cam;
bLink_to_cam.transform.rotation.x = quat.x();
bLink_to_cam.transform.rotation.y = quat.y();
bLink_to_cam.transform.rotation.z = quat.z();
bLink_to_cam.transform.rotation.w = quat.w();
//Set translations
bLink_to_cam.transform.translation.x = 0;
bLink_to_cam.transform.translation.y = 0;
bLink_to_cam.transform.translation.z = 0;
In another node, I have a tf::TransformListener
object which receives this transform. Here I print out the values :
void printEulerAngles(tf::StampedTransform& transform){
tf::Matrix3x3 m(transform.getRotation());
m.getRPY(roll, pitch, yaw);
//m.getEulerZYX(yaw, pitch, roll);
ROS_INFO("\nRoll : %.3f\n"
"Pitch : %.3f\n"
"Yaw : %.3f\n",
RADIANS_TO_DEGREES(roll), RADIANS_TO_DEGREES(pitch), RADIANS_TO_DEGREES(yaw) );
I expected to see the transform as defined above. However, I see Roll, Pitch, Yaw (90,90, 0). I did some research and found that setRPY()
and getRPY()
follow this convention:
- (roll around X, pitch around Y and yaw around z) around fixed axes.
Here are my questions:
- How do I define rotations when I need to rotate (w.r.t to base_link axes) in the following convention?
- (yaw around Z, then pitch around new Y, then roll around new X)
- Once I get the above rotation from tf, how do I modify the
printEulerAngles()
method to display them in the same convention as above?
I'd really appreciate any assistance in understanding tf. Thanks!
Originally posted by Venkat Ganesh on ROS Answers with karma: 57 on 2016-11-10
