I have tried to add some STL objects into the scene in RVIZ (add object as a file option). It seems that more complex models failed to render in rviz. The simplest ones renders well. [I can't load a file to show you the "invisible" model] I am using ROS Indigo under Ubuntu in Virtual Box VW. Any suggestions?
Originally posted by Kate Zabelova on ROS Answers with karma: 13 on 2016-11-07
Comment by gvdhoorn on 2016-11-07:
RViz is quite a graphically heavy application, especially if you have complex meshes (ie: high nrs of vertices and faces) in your scene. VMs haven't had the best performance in these cases. Not sure, but the two could be related. Do those meshes load properly in fi Meshlab or other tools?
Comment by Kate Zabelova on 2016-11-07:
@gvdhoorn, yes, the models load properly in other tools. The problem appears with .stl files, approximately larger than 1MB. Is it possible to improve the performance of the VM?
Comment by gvdhoorn on 2016-11-08:
If at all possible, please provide us with a way to replicate your issue, either by making the meshes that show the problem available, or by creating something else (other meshes) that are also problematic.
re: improve performance of vm: have you installed the proper drivers for the vm hw? Most likely current Ubuntu distributions include all the necessary drivers for VirtualBox hw, but it's a good thing to check. Does glxgears
run properly?
Comment by Kate Zabelova on 2016-11-09:
@gvdhoorn here is arm model that I have tried to add into the scene.
@gvdhoorn Yes, glxgears run properly
