I have a ROS node that is listening for messages on a topic, and when it receives a 'START' message it makes a call to an instance function of another class JointRecorder.record_playback(). What I want to happen is for the listener to continue listening for a 'STOP' message and execute the instance function concurrently, so that when the 'STOP' message is received it can terminate execution of the instance function. But, right now it just makes a synchronous call to the instance function and waits for it to complete, so the listener never receives the 'STOP' message. How can I have it both listen and execute the instance function?
class JointTrajectoryRecorder:
    def __init__(self, limb, rate, filename):
        self.limb = limb
        self.rate = rate
        self.filename = filename
        self.pub = rospy.Publisher('playback_cmds', String, queue_size=10)
        rospy.init_node('joint_trajectory_recorder', anonymous=True)
        rospy.Subscriber('record_cmds', String, self.respond)
        self.recorder = JointRecorder(self.limb, self.rate)
    def respond(self, cmd):
        # not sure if it will take command while still recording
        if cmd.data == _START_REC:
            self.recorder.record_playback()
        elif cmd.data == _STOP_REC:
            self.recorder.stop()
        elif cmd.data == _DONE:
            self.recorder.persist_data(self.filename)
        else:
            print "Command unknown:", cmd.data
    def run(self):
        print("Getting robot state... ")
        rs = baxter_interface.RobotEnable(CHECK_VERSION)
        print("Enabling robot... ")
        rs.enable()
        print("Running. Ctrl-c to quit")
class JointRecorder:
    def __init__(self, limb, rate):
        self.limb = limb
        self.rate = rospy.Rate(rate)
        self.start_time = rospy.get_time()
        self.arm = baxter_interface.Limb(self.limb)
        self.nominal = Trajectory(self.arm.joint_names(), self.rate)
        self.recordings = []
        self.nav = baxter_interface.Navigator(self.limb)
        self.is_recording = False
        self.is_done = False
    def time_stamp(self):
        return rospy.get_time() - self.start_time
    def stop(self, button_value=True):
        self.is_done = True
    def done(self):
        if rospy.is_shutdown():
            self.stop()
        return self.is_done
    def set_recording(self, button_value):
        self.is_recording = True
    def record_playback(self):
        print "\nRecording playback trajectory..."
        t = Trajectory(self.arm.joint_names(), self.rate)
        while not self.done():
            t.add_timestep(self.time_stamp())
            for name in self.arm.joint_names():
                t.add_position(name, self.arm.joint_angle(name))
            self.rate.sleep()
        self.recordings.append(t)
        print "Playback recording complete."
Originally posted by adamconkey on ROS Answers with karma: 642 on 2016-10-18
You will have to return from the callback to receive another callback on the next message. So, the work loop must be running in another tread, maybe in the main thread. It can be as simple as something like:
  • in the callback just save the received message to some variable
  • in the main loop wait for it to become _START_REC, then do your stuff while checking for it to become _STOP_REC
Originally posted by Girts L with karma: 196 on 2016-10-23
