My env: Ubuntu 16.04 (Xenial), ROS kinetic.
I need to work with Reem robot simulation. I tried following instructions as per Launching a REEM Gazebo simulation. But got stuck at
$ rosdep install --from-paths src --ignore-src --rosdistro hydro -y
which returned
ERROR the following packages/stacks could not have their rosdep keys resolved to system dependencies
reem_tabletop_grasping: No definition of [object_recognition_msgs] for OS version [xenial]
reem_moveit_config No definition of [moveit_simple_controller_manager] for OS version [xenial]
So how do I get this running. Should I install Ros Hydro? But ROS Hydro ONLY supports Precise, Quantal, and Raring for debian packages, as per Ubuntu install of ROS Hydro.
Should I install Ubuntu Raring for this now? Thank You
Edit: tried $ rosdep install --from-paths src --ignore-src -y
It says,
ERROR: the following packages/stacks could not have their rosdep keys resolved
to system dependencies:
reem_tabletop_grasping: Cannot locate rosdep definition for [moveit_commander]
reem_bringup: Cannot locate rosdep definition for [play_motion]
reem_object_recognition: Cannot locate rosdep definition for [object_recognition_tabletop]
reem_moveit_config: Cannot locate rosdep definition for [moveit_simple_controller_manager]
Originally posted by r0josh on ROS Answers with karma: 3 on 2016-10-12
Comment by gvdhoorn on 2016-10-12:
Please check your question after / before posting it. I've had to significantly edit it, as it was completely unreadable before. Using proper formatting will make it easier for other users to help you, which in turn increases your chances of getting good answers.
Comment by r0josh on 2016-10-12:
Thank u @gvdhoorm. Sorry for the noobie formatting (I really am a noobie). I didn't understand how to get the 'code' block and a blank line.
Comment by gvdhoorn on 2016-10-14:
Your latest edit seems to suggest this is a new problem (you're not running 16.04 anymore). I would suggest you open a new question for that to keep things clear for future readers.
Apart from that: do you have ros-hydro-imu-sensor-controller installed? The REEM pkgs may not declare that dep.
Comment by r0josh on 2016-10-14:
I was hoping REEM pkgs to handle that. Thanks a lot for the tip.
The reem pkgs should have that dependency declared, yes, but if they don't, then a rosdep install .. won't pick them up. Perhaps report the issue over at their bug tracker.
Also: I just noticed that there is an Indigo version of all of this. That would probably have had a better chance to work on Kinetic than the Hydro version ..
I too found indigo version for REEM C robot. Is that gonna work with REEM?
Probably not. REEM is a different robot from REEM C. I was actually referring to reemc-sim-indigo.rosinstall.
I haven't tried it, but you could see whether leaving off the --rosdistro hydro from the rosdep install .. command makes this work.
No guarantees, as the main wiki/Robots/REEM explicitly mentions Hydro as being the target platform.
Edit: MoveIt hasn't been released on Kinetic, so rosdep cannot resolve those two packages. You can see whether things will work if you build it from source.
Originally posted by gvdhoorn with karma: 86574 on 2016-10-12
Comment by r0josh on 2016-10-13:
Tried that, didn't work. Created a bootable USB with 13.04 and met with "Kernel Panic". Looks like a bad day. Getting 12.04 now.
Comment by gvdhoorn on 2016-10-13:
"Didn't work" is not really informative. What happened?
Thank You for that edit. It seems to be in Beta. I'm skeptical.
(moveit maintainer here): we have multiple ppl building moveit from source on Kinetic and using it daily. There are some rough edges, but the install instructions should work. If they don't, please report to the moveit issue tracker on github.
Btw: I'd recommend using a workspace underlay for MoveIt. Then overlay your reem workspace on top of that.
Could you pls point me to some sort of a guide/tutorial.
For building MoveIt? See the 'from source' link I posted above.
For overlaying workspaces? See Overlaying with catkin workspaces.
