Hi!!
I'm trying to make my own Turtlebot using a Roomba 645 base, a Kinect sensor and ROS Indigo. I would like to use this platform to make maps (SLAM) using Gmapping package for example.
I've trying to use it with some packages changing the parameters for the roomba base, but the communication fails. Does Someone has try to use the Turtlebot package for roomba 600 base with success?
Thanks!!!
Greetings
Originally posted by Diana_Elyza on ROS Answers with karma: 15 on 2016-10-06
You can take a look at AutonomyLab/create_autonomy: ROS driver for iRobot Create 1 and 2. . According to its REAME, it may support the 600 series.
Originally posted by Mani with karma: 1704 on 2016-10-06
Comment by Diana_Elyza on 2016-10-06:
Thank you Mani!!!
I've worked it and it works but I don't know how to use it with the Kinect and the Gmapping package. I'm newbie in this.
Greetings
Comment by Mani on 2016-10-06:
You are welcome. Now that the base is working, you need to pretty much go through all the tutorials regarding how to setup your custom robot, setting up its kinematic (TF) tree and how to do gmapping/amcl and how to navigate your robot with the ROS navigation stack.
You might be able to re-use many components of the current turtlebot packages, essentially replacing the base driver with create_autonomy, update the description files and tweak the launch/configuration files.
Thank you very much!!!
I'll follow your suggestions.
Greetings =)
You are welcome. It is going to be a rewarding process. Good luck! (PS. If this answer solved your issue, it would be great if you mark it as correct)
