Hi, I have an installation problem. By running "sudo apt-get install ros-kinetic-desktop" on a Ubuntu 16.04.1 LTS (Xenial) i have the following output
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-kinetic-desktop :
Depends: ros-kinetic-common-tutorials but it is not going to be installed
   Depends: ros-kinetic-geometry-tutorials but it is not going to be installed
   Depends: ros-kinetic-robot but it is not going to be installed
   Depends: ros-kinetic-ros-tutorials but it is not going to be installed
   Depends: ros-kinetic-urdf-tutorial but it is not going to be installed
   Depends: ros-kinetic-visualization-tutorials but it is not going to be installed
   Depends: ros-kinetic-viz but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
what can i do? thanks in advance
Originally posted by aerydna on ROS Answers with karma: 51 on 2016-10-04
Comment by Davide Faconti on 2016-10-20:
same problem here. Did you manage to solve it?
4 Answers 4
I had a similar problem and I managed to solve it by correctly installing restricted, universe, and multiverse repositories as it is described in link.
My problem was that the packages seemed to be installed however, they were not able to find some of their packages. I solved that problem by changing the Download From to Main Server in Ubuntu's software and update.
I also explained my solution here: link
Originally posted by tekin with karma: 86 on 2017-07-05
I had a similar (probably the same) problem. To check if you problem is similar to mine, try installing this package:
sudo apt-get install ros-kinetic-python-qt-binding
If apt-get complains about unmet dependency libpyside2-dev, than it is actually the same problem.
The solution for me was to remove a bunch of packages and install them again:
libpyside2-dev, libshiboken2-dev, pyqt5-dev, python-pyqt5, python-pyqt5.qtsvg, python-pyside2, python-sip-dev, shiboken2, qtbase5-dev, qt5-qmake and all the packages starting with libqt5.
In short, the problem was probably related to a newer version of qt5 being installed on my system. I hope this helps.
Originally posted by Davide Faconti with karma: 308 on 2016-10-20
Comment by sindhu on 2016-11-08:
how to remove and reinstall those packages? Please explain in detail
Comment by jdmartin86 on 2016-12-19:
I verified the unmet dependency, and this solution still did not't help me.
Comment by merosss on 2018-07-11:
Thanks this was the solution for me! qt5 was breaking ros installation
Comment by Jägermeister on 2018-10-10:
I installed that qt binding but I still cannot install the full desktop ros.
Hi, guys, I've solved the same problem by adding deb http://cz.archive.ubuntu.com/ubuntu xenial main universe to the file /etc/apt/sources.list, and run the command sudo apt-get update, then install the kinetic by run sudo apt-get install ros-kinetic-desktop-full, everything went smoothly. You guys can visit the link https://packages.ubuntu.com/xenial/all/python-qt-binding/download for more detail. Davide Faconti is right, the problem is the lack of python-qt-binding in the system or something goes with the packages.
Nope, this did not work for me.
Comment by jleng on 2020-10-22:
This worked for me like a charm. I added the stuff into sources.list and thanks for reminding me that I need to run sudo apt-get update for it to take effect!
Add following package sources to /etc/apt/sources.list.
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
deb http://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-security main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-updates main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-proposed main restricted universe multiverse
deb-src http://mirrors.ustc.edu.cn/ubuntu/ xenial-backports main restricted universe multiverse
Now, follow these steps from 1.2 in this link
Comment by ruderik on 2018-03-15:
this worked for me!
Comment by Fan on 2019-10-30:
after this, I did sudo apt-get update, then run sudo apt-get install ros-kinetic-desktop, and it worked
