I have been using ROS for a few days and I am following the tutorial for setting up the Navigation Stack. It tells me to create a package as follows:
catkin_create_pkg my_robot_name_2dnav move_base my_tf_configuration_dep my_odom_configuration_dep my_sensor_configuration_dep
Since tf and odom are handled in the zen package, and my sensor is a Kinect, my actual command is:
catkin_create_pkg zen_2dnav2 move_base freenect_launch zen
When I execute catkin_make I get an error due to move_base:
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
Could not find a package configuration file provided by "move_base" with
any of the following names:
  move_baseConfig.cmake
  move_base-config.cmake
I googled and subsequently removed the error by:
  • Removing the build-Dependency on move_base from package.xml
  • Removing move_base from find_package(catkin REQUIRED COMPONENTS ...) in CMakeLists.txt
So my questions in order of importance are:
  • Why did I get the error ?
  • What are the implications of removing the dependency ? i.e. Will the Navigation Stack fail because of this
  • During my googling I read that move_base is not catkinized and a catkin package cannot depend on it. Does that mean the tutorial is doomed to failure. I am hoping the information is out of date and move_base IS catkinized. How can I check this ? Is there an up to date list of packages that work in Kinetic ?
Originally posted by elpidiovaldez on ROS Answers with karma: 142 on 2016-09-29
Why did I get the error?
You are probably getting the error because the move_base package is not installed in your machine. Try to execute the command:
sudo apt-get install ros-kinetic-navigation
It will install all the packages you need to run the navigation stack.
By removing the dependency your package will fail to compile if it uses any library or header file defined in mobile_base package.
That information is out of date. The package move_base is indeed catkinized. You can check it by taking a look at move_base's CMakeLists.txt file.
roscd move_base
cat CMakeLists.txt
You will see that it uses the proper catkin macros.
If you want to see a list of available packages in Kinetic, execute:
sudo apt-get update
apt-cache search ros-kinetic
I hope this helps
Originally posted by Martin Peris with karma: 5625 on 2016-09-29
Comment by elpidiovaldez on 2016-09-30:
Exactly what I needed on all my questions. Thank you very much.
I see now that I was trying to setup the navigation stack without actually having installed it. I am amazed I got as far as I did !
Comment by Martin Peris on 2016-09-30:
I am glad this solved your issue. If you are happy with the answer, please, mark it as "correct" using the ✅ button. This way people with the same problem can know that this is the correct answer.
Comment by elpidiovaldez on 2016-10-02:
I tried to do something to accept your answer for ages, but couldn't find what to click. Thanks for the clue. I was looking where I see 'edit', 'retag' 'close' etc. and had missed that rather understated tick icon. Now done, and thanks again.
