I am using a main computer to launch the ros nodes in 4 robots. These robots have odroids. I can ssh into the robots by name:
ssh [email protected]
I can ssh by name to all the robots except 1 [email protected]. To that one I need to ssh by ip address but I need to ssh by name to launch the nodes on it.
The network is done with a router, and something funny is happening. If I do not connect the router to internet I cannot ssh odroid-machine4.local by name, only by ip address. If a connect the router to internet everything is fine. The thing is that for some of my experiments I need to move to a place where I do not have internet access.
I think I might have some configuration problems but I do not know how to debug them.
Today I reinstalled Ubuntu from zero on odroid-machine4.local. Then I reinstalled all the software and configured the network as I always do for all the robots. I was able to ssh odroid-machine4.local by name. Then I connected all the robots to the network and again odroid-machine4.local was not recognized by name. It was until I connected the router to internet that I was able to ssh by name.
I even tried with a different router and I have the same problem.
I think I need to configure something but I don't know what.
Originally posted by Luis Ruiz on ROS Answers with karma: 114 on 2016-09-27
Comment by gvdhoorn on 2016-09-27:
I sympathise, but technically, this isn't really a ROS-related question, correct?
Comment by Luis Ruiz on 2016-09-27:
Well, I use it on robots using ROS, so maybe someone had this issue and can guide me.
So which device is performing the DNS server role here? The router? Or are you depending on bonjour / avahi-like services? Can all the hosts resolve all other hostnames? Is it just the desktop machine that can't resolve the odroid-machine4 name, or do all hosts have problems?
I asked here and solved the problem. I had to configure the /etc/hosts files properly.
Originally posted by Luis Ruiz with karma: 114 on 2016-09-28
Comment by gvdhoorn on 2016-09-28:
A name resolution issue then? Strange that it did work for odroid1 to 3, but not for 4. I would've expected it to never work, or always.
Thanks for reporting back.
