Hey, I am new to ROS and want to work with pointclouds. I did exactly the ROS PCL tutorial as written in http://wiki.ros.org/pcl/Tutorials
CMakeLists in ~/catkin_ws/src/my_pcl_tutorial:
project(my_pcl_tutorial)
  pcl_conversions
  pcl_ros
  roscpp
  sensor_msgs
include_directories(
  ${catkin_INCLUDE_DIRS}
add_executable(example src/example.cpp)
target_link_libraries(example ${catkin_LIBRARIES})
package.xml:
  <?xml version="1.0"?>
  <package>
  <name>my_pcl_tutorial</name>
  <version>0.0.0</version>
  <description>The my_pcl_tutorial package</description>
  <maintainer email="[email protected]">viki</maintainer>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>pcl_conversions</build_depend>
  <build_depend>pcl_ros</build_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>sensor_msgs</build_depend>
  <build_depend>libpcl-all-dev</build_depend>
  <run_depend>libpcl-all</run_depend>
  <run_depend>pcl_conversions</run_depend>
  <run_depend>pcl_ros</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>sensor_msgs</run_depend>
  <export>
  </export>
</package>
, but it does not seem to incorporate the package:
rosrun error:
rosrun my_pcl_tutorial example input:=/narrow_stereo_textured/points2
[rospack] Error: package 'my_pcl_tutorial' not found
Version: Indigo 1.11.8, but it does not work on jade either. I did all the previous standard ROS tutorials, but dumpster beginner mistakes likely happened. Any help is appreciated.
Originally posted by anonymous28046 on ROS Answers with karma: 65 on 2016-09-22
Well, after a few minutes of doing nothing regarding ROS at all, it apparently finds the package now. Sorry, but I have no idea why it is working after the delay.
Command line history:
784  catkin_make
  785  cd ~/catkin_ws/
  786  roscore
  787  source devel/setup.bash
  788  roscore
  789  rosrun my_pcl_tutorial example input:=/narrow_stereo_textured/points2  ##did not work here##
  790  cd ~/catkin_ws/
  791  source devel/setup.bash
  792  printenv | grep ROS
  793  cd devel
  794  ls -a
  795  cd include/
  796  ls -a
  797  cd ..
  798  cd src
  799  ls -a
  800  cd ..
  801  printenv | grep ROS
  802  rospack find my_pcl_tutorial
  803  roscore
  804  cd ~/catkin_ws/
  805  rosrun my_pcl_tutorial example input:=/narrow_stereo_textured/points2 ##works
Originally posted by anonymous28046 with karma: 65 on 2016-09-23
Comment by anonymous28046 on 2016-10-11:
This is the solution, I just can not accept it as I do not have enough points.
