Hello,
TL;DR tf::TransformListener gets a different transform than shown in RVIZ
I am having quite a strange problem. I am using a rosbag file to playback recorded data and I am adding new transforms and using them while doing that:
rosparam set use_sim_time true
rosbag play 2016-09-12-14-51-41.bag --clock
The transform is published with a python node, where the origin is static (defined with cfg-values) and the rotation is coming from the values of an IMU. The interesting part how the tf is published should be this (in the callback of the IMU subscription):
  br = tf.TransformBroadcaster()
  br.sendTransform((frame_offset_x, frame_offset_y, frame_offset_z),
               quaternion,
               rospy.Time.now(),
               frame_child,
               frame_parent
With the following values:
  frame_offset_x = 0
  frame_offset_y = 0
  frame_offset_z = 1.2
  quaternion = rotation of the IMU (only around the x and y axis)
  frame_child = level_laser_2
  frame_parent = base_footprint
The created Transform in RVIZ looks like expected. It's 1.2m above base_footprint with some rotation on top. In the picture, the Fixed Frame is set to "base_footprint"
level_tf in RVIZ
However if I lookup the transform in a ROS node using the tf::TransformListener I get a different result:
#include <tf/transform_datatypes.h>
#include <tf/transform_listener.h>
  tf_listener_ = new tf::TransformListener( ros::Duration(10) ); // in the constructor
void callback( const sensor_msgs::PointCloud2Ptr& cloud_in ) {
  if ( tf_listener_->waitForTransform(tf_target_,
                                      cloud_in->header.frame_id,
                                      cloud_in->header.stamp,
                                      ros::Duration( scan_time_ )) ) {
    tf::StampedTransform transform;
    tf_listener_->lookupTransform(tf_target_,
                                  transform);
    ROS_INFO("%s %s -> %s\tat%lf", node_name_.c_str(),
                                   cloud_in->header.frame_id.c_str(),
                                   tf_target_.c_str(),
                                   cloud_in->header.stamp.toSec());
    tfScalar tf[16];
    transform.getOpenGLMatrix(tf);
    ROS_INFO("%s\n"
             "/ %lf\t%lf\t%lf\t%lf \\\n"
             "| %lf\t%lf\t%lf\t%lf |\n"
             "\\ %lf\t%lf\t%lf\t%lf /", node_name_.c_str(),
             tf[0], tf[4], tf[8], tf[12],
             tf[1], tf[5], tf[9], tf[13],
             tf[2], tf[6], tf[10], tf[14],
             tf[3], tf[7], tf[11], tf[15]);
  } else {
    // display error here
The output of this is:
[ INFO] [1473756806.521699009, 1473684710.202103154]: /level_laser_velodyne:  base_footprint -> level_laser_2 at1473684709.395050
[ INFO] [1473756806.521764836, 1473684710.202103154]: /level_laser_velodyne:
/ 0.997645  0.001908    -0.068567   0.002741 \
| 0.001908  0.998454    0.055557    -0.002221 |
| 0.068567  -0.055557   0.996098    -0.039822 |
\ 0.000000  0.000000    0.000000    1.000000 /
But it should be something like:
/ R R R 0 \
| R R R 0 |
| R R R 1.2 |
\ 0 0 0 1 /
Does anybody know what I am doing wrong?
Thank you for your help, Tobias
Originally posted by Tobias Neumann on ROS Answers with karma: 179 on 2016-09-13
I think you need to swap target and source frames in lookupTransform.
I know it is confusing, but I guess the way to think about it is that lookupTransform returns a way of transforming data from source_frame to target_frame. So if you want to know where child is relative to its parent, parent is the target frame, because you want to express the position and orientation of child while looking from parent's frame.
Originally posted by artifactz with karma: 119 on 2018-11-06
Post score: 4
Comment by Tobias Neumann on 2018-11-07:
Thank you, that might've be wrong as well. But I would have expected a translation of 1.2m, instead I got something around 4cm.
However since this question is over 2 years old, I solved it a different way.
It's not solved, but I've found a workaround by using a different node and therefore I'm closing this question.
I'm sorry that I can't help someone running into the same problem and ending up at this question.
Originally posted by Tobias Neumann with karma: 179 on 2018-11-07
