I've successfully added a force torque/sensor to my model by adding following codes in my urdf file:
<gazebo reference="shoulder_pan_joint">
    <provideFeedback>true</provideFeedback>
</gazebo>
<gazebo>
    <plugin name="ft_sensor" filename="libgazebo_ros_ft_sensor.so">
        <updateRate>10.0</updateRate>
        <topicName>ft_sensor_topic</topicName>
        <jointName>shoulder_pan_joint</jointName>
    </plugin>
</gazebo>
Although the model is static and nothing is moving in gazebo gui, the outputs of force/torque sensor published by "ft_sensor_topic" is fluctuating. For example the force value that I expect to be -100 is fluctuating between -55 N and -143N. Other 5 components of torque and force values are also fluctuating in a similar range.
I also tried to reduce Gaussian Noise of the sensor by adding <gaussianNoise>0.0</gaussianNoise> to the plugin tag. but this didn't solve the problem.
I'm using gazebo 2.2.3 + Ros indigo running in ubuntu 14.04.
Originally posted by Masoud on ROS Answers with karma: 41 on 2016-09-06
I realize this is an old post, however I found that the torque/force plugin for gazebo was giving very large values even when my model was stationary. Generating better inertial values made the reported values much better (http://answers.gazebosim.org/question/4372/the-inertia-matrix-explained)
Originally posted by KurtR with karma: 16 on 2018-08-09
