Hey all,
I am trying to move my catkin workspace from my old computer to my new one. I copied the folder from my old computer, pasted into the new one with ROS installed. catkin)make gave no errors. However, when i try to run my program, i get this error:
$ rosrun sim_pkg sim_init [rosrun] Couldn't find executable named sim_init below /home/icepaka89/algsim_ws/src/sim_pkg
Clearly there is a problem with ROS_PACKAGE_PATH. But I can't seem to figure it out? Does anyone know an easy way to fix this? I made sure i ran source devel/setup.bash before running my program. Thanks!
Originally posted by icepaka89 on ROS Answers with karma: 33 on 2016-09-02
You need to go to the directory where your executable is, and check if it is there. Usually, the executable generated is in the [WORKSPACE_DIR]/devel/lib/[PKG_NAME]/.
If the executable is not generated, then something wrong with catkin_make or your source code.
If the executable is generated, then something wrong with you environment variables.
Originally posted by Shay with karma: 763 on 2016-09-02
