Learning ROS from Mastering ROS for Robotics Programming book from yesterday. Actually i struck up in configuring talker & listener.
Configuration & Errors as follows. I need some help to clear the error.
ROS Indigo Ubuntu 14.04
CATKIN_MAKE:
roos@roos-Inspiron-1520:~$ cd catkin_ws
roos@roos-Inspiron-1520:~/catkin_ws$ catkin_make mastering_ros_demo_pkg
Base path: /home/roos/catkin_ws
Source space: /home/roos/catkin_ws/src
Build space: /home/roos/catkin_ws/build
Devel space: /home/roos/catkin_ws/devel
Install space: /home/roos/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/roos/catkin_ws/build"
#### Running command: "make mastering_ros_demo_pkg -j2 -l2" in "/home/roos/catkin_ws/build"
roos@roos-Inspiron-1520:~/catkin_ws$ roscore
... logging to /home/roos/.ros/log/58f9d6ee-6de2-11e6-aed6-001d09bb3726/roslaunch-roos-Inspiron-1520-17202.log
Press Ctrl-C to interrupt
started roslaunch server http://roos-Inspiron-1520:38168/
ros_comm version 1.11.20
SUMMARY
PARAMETERS
 * /rosdistro: indigo
 * /rosversion: 1.11.20
NODES
auto-starting new master
process[master]: started with pid [17214]
ROS_MASTER_URI=http://roos-Inspiron-1520:11311/
setting /run_id to 58f9d6ee-6de2-11e6-aed6-001d09bb3726
process[rosout-1]: started with pid [17227]
started core service [/rosout]
WHILE RUNNING TALKER & LISTENER I AM GETTING FOLLOWING ERROR:
roos@roos-Inspiron-1520:~$ rosrun mastering_ros_demo_pkg demo_topic_publisher
[rospack] Error: package 'mastering_ros_demo_pkg' not found
roos@roos-Inspiron-1520:~$ rosrun mastering_ros_demo_pkg demo_topic_subscriber
Originally posted by Robotfreak on ROS Answers with karma: 1 on 2016-08-29
Did you add the workspace to your ROS environment?
When you open a new terminal, try this first before running rosrun :
$ source ~/catkin_ws/devel/setup.bash
Originally posted by bhavyadoshi26 with karma: 95 on 2016-08-29
