I was following ros control tutorial to control robot in gazebo with ros, but as i try to build the package by running catkin_make i get this error:
-- Could not find the required component 'ros_control'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  Could not find a package configuration file provided by "ros_control" with
  any of the following names:
    ros_controlConfig.cmake
    ros_control-config.cmake
  Add the installation prefix of "ros_control" to CMAKE_PREFIX_PATH or set
  "ros_control_DIR" to a directory containing one of the above files.  If
  "ros_control" provides a separate development package or SDK, be sure it
  has been installed.
  myrobot_control/CMakeLists.txt:7 (find_package)
my CMakeLists.txt file is:
project(myrobot_control)
  ros_control
  ros_controllers
    catkin_package()
include_directories(
  ${catkin_INCLUDE_DIRS}
I installed the ros_control package using sudo apt-get install ros-indigo-ros-control but it didn't worked.
Originally posted by dinesh on ROS Answers with karma: 932 on 2016-08-25
Ok problem, solved i have to install 2 extra packages which is not mentioned in the documentation also, and these are:
 sudo apt-get install ros-indigo-effort-controllers
 sudo apt-get install ros-indigo-joint-state-controller
Originally posted by dinesh with karma: 932 on 2016-08-25
Comment by abhay2302 on 2017-05-02:
helped for me
