Hello everyone.
I started a new install of ROS Kinetic, and I was hoping to use a few CUDA features from OpenCV. I have successfully compiled and tested CUDA and OpenCV (which is installed in /usr/local), but I am having trouble using my OpenCV instead of the ros-kinetic-opencv3 package.
I have tried adding /usr/local to the front of my CMAKE_PREFIX_PATH, as well renaming the opencv pkgconfig file in /opt/ros/lib/pkconfig. However I still get the below error, indicating that I am building against the ROS OpenCv.
OpenCV Error: No CUDA support (The library is compiled without CUDA support) in throw_no_cuda, file /tmp/binarydeb/ros-kinetic-opencv3-3.1.0/modules/core/include/opencv2/core/private.cuda.hpp, line 97
terminate called after throwing an instance of 'cv::Exception'
  what():  /tmp/binarydeb/ros-kinetic-opencv3-3.1.0/modules/core/include/opencv2/core/private.cuda.hpp:97: error: (-216) The library is compiled without CUDA support in function throw_no_cuda
Any ideas?
Originally posted by daniel_dsouza on ROS Answers with karma: 258 on 2016-08-24
Comment by ahendrix on 2016-08-25:
It looks like its loading the wrong library at runtime; this is usually controlled by the system library search paths (ldconfig) and LD_LIBRARY_PATH
Comment by daniel_dsouza on 2016-08-25:
LD_LIBRARY_PATH looks like /usr/local/lib:/home/user/catkin_ws/devel/lib:/opt/ros/kinetic/lib
shouldn't it be pulling from /usr/local/lib where OpenCV is first if that was the case?
if I manually run the CMakeLists.txt file, then the code build and executes correctly. However using catkin_make give different results?
Comment by ashwath1993 on 2017-06-15:
@daniel_dsouza, how did you run it manually? Just CMake .. and make?
Comment by daniel_dsouza on 2017-06-15:
I believe so. Do you have a Github link to your code? I can try to compile it myself.
https://github.com/ashnarayan13/stereo_works.git this is the code.
Could you please link your entire ros package? Until then, look at this (working) example https://github.com/daniel-dsouza/solid-succotash
@daniel_dsouza I have added the entire projecct on git. I will look into your project as well! Thanks!
Comment by ashwath1993 on 2017-06-19:
my CMakeCache.txt points the opencv dir to /usr/local/share/OpenCV but the headers i require are in /usr/local/include/opencv2 . Even if set the cmake cache to that location, i get an error and then resets to share/opencv. I get undefined reference to `cv::cuda::createStereoBM(int, int)'
Hello previous me,
So you have the opencv3 package installed, which provides libraries in /opt/ros/kinetic/lib, and you also have OpenCV compiled from source, installed to usr/local. The trick is to tell catkin to use the libraries from usr/local.
By default, catkin is hardwired to look for packages in your workspace, then in /opt/ros/kinetic. CMake by itself will use the libraries in /usr/local. I tried to prioritize /usr/local by modifying the CMAKE_PREFIX_PATH environment variable, as suggested in pre kinetic posts, but no luck.
So if I cannot modify catkin itself, I should to explicitly tell CMake which OpenCV to use. I had to change my declaration from
find_package(OpenCV REQUIRED)
to
NO_MODULE # should be optional, tells CMake to use config mode
PATHS /usr/local # look here
NO_DEFAULT_PATH) # and don't look anywhere else
So that will pull in the correct libraries. If another package is built that requires OpenCV, catkin will also pull in the wrong dependencies. Mixed dependencies is a bad thing. So you have to add the modified OpenCV configuration to any other packages that require OpenCV. This includes the vision_opencv package that provides cv_bridge.
UPDATE 10/12/2017: Please see my fork of vision_opencv for the necessary changes and my cvTest example package. In the example, I demonstrate the use of my custom version of OpenCV 3.3 build with CUDA 8.
Originally posted by daniel_dsouza with karma: 258 on 2016-09-01
Post score: 9
Comment by ashwath1993 on 2017-05-27:
I have a similar problem. I replaced the CMake file as you have, but I still get the same error. find_package(OpenCV REQUIRED NO_MODULE PATHS /usr/local NO_DEFAULT_PATH) I can compile the code and run it outside ROS.
Comment by naveenT1010 on 2017-05-28:
ashwath1993 did you recompile other packages dependent on opencv or not? I was also having a similar problem, but when I compiled the vision_opencv from source, it all worked.
Comment by ashwath1993 on 2017-06-12:
I am able to run the opencv samples from the same path. Doesn't work with ROS alone.
what(): /tmp/binarydeb/ros-kinetic-opencv3-3.2.0/modules/core/include/opencv2/core/private.cuda.hpp:97: error: (-216) The library is compiled without CUDA support in function throw_no_cuda My CMakeLists.txt contain the same find_package as you have mentioned
Comment by k_totoro on 2017-10-12:
Hi. I have same trouble and got same error. In the sentence "So you have to add the modified OpenCV configuration to any other packages that require OpenCV.", do you mean I have to change all Cmakelist in my packages?
Comment by daniel_dsouza on 2017-10-12:
@k_totoro Hello. I had to download the vision_opencv metapackage , and make the above changes to the cv_bridge and image_geometry packages' CMakeLists.txt. You only need to make the changes in packages that use/are used by your node that uses your custom OpenCV.
@k_totoro, please see the update to my answer with the github repo
Comment by k_totoro on 2017-10-13:
Thank you daniel. I read your Github sample but still do not understand what you mean. So, I have to remove my "cv_bridge" or some package from apt-get and rebuild it for myself? Your test CMake file in CVTest looks the same with mine.
Finally, I found I had to exclude opencvcore3.so in my catkin_libraries. Here is my issue and thank you for your help! https://answers.ros.org/question/272814/how-to-tell-catkin_make-to-use-opencv-with-gpu/ My sample project: https://github.com/YoshiRi/ros_opencv_conflict/blob/master/CMakeLists.txt
Comment by daniel_dsouza on 2017-10-14:
Good for you! To answer your question, you would have to recompile the packages in vision_opencv to make sure the correct libs are used. You could use the fork I posted.
Comment by surfertas on 2017-10-26:
@daniel_dsouza @k_totoro In my case, I took the following steps after all the steps mentioned above.
$ cd catkin_ws/src
$ git clone https://github.com/daniel-dsouza/vision_opencv.git
$ cd ..
$ catkin clean
$ catkin build
Which seemed to do the job. I didnt have to remove any additional file
Comment by Redhwan on 2019-10-11:
@daniel_dsouza thank you so much, I just downloaded your https://github.com/daniel-dsouza/vision_opencv in my ~/catkin_ws/src/, then making ~/catkin_ws/catkin_make on my PC, It is very nice but tried to use the same steps in my Jetson TX2 with OpenCV4Tegra because I don't need to build OpenCV like on my PC but get this ERROR , you can see here in my question. I think that the issue in the path, please help me or any suggestions?
Comment by j.clownz on 2021-02-17:
@daniel_dsouza That saved my life. Thanks man!
