Hi, I just start with ROS and UWsim
I am trying to install new scenes because i want to modified a scene for my project.
I follow the guide on this answer
http://answers.ros.org/question/234836/uwsim-unable-to-execute-scene-installer-script-for-package-based-installation-of-uw-sim/
I download the sh file from this link
http://www.irs.uji.es/uwsim/files/scenes/installScene
then
copy and paste the file into the path
/opt/ros/indigo/share/uwsim/data/scenes
Then I try to run the line:
sudo /opt/ros/indigo/share/uwsim/data/scenes/installScene.sh -s pipes_scene.uws
and I get:
root@wilmer-VirtualBox:~# sudo /opt/ros/indigo/share/uwsim/data/scenes/installScene.sh -s pipes_scene.uws sudo: /opt/ros/indigo/share/uwsim/data/scenes/installScene.sh: command not found
what am I doing wrong?
Originally posted by Wilmer on ROS Answers with karma: 18 on 2016-08-22
For some reason the saved file was not been recognized as a command i download from other source and moved to the folder
Originally posted by Wilmer with karma: 18 on 2016-08-23
Comment by Airuno2L on 2016-08-23:
You can mark this as solved by clicking the check mark next to your answer.
Comment by Wilmer on 2016-08-30:
No, i can't because I don't have 10 points
Comment by Hossein92 on 2018-04-25:
guys i have this problem too, what should i do?
