I am using sync_policies::ApproximateTime in message_filter to do the PointCloud2 and LaserScan time synchronization, but the problem is it cannot enter into the callback function ofsync.registerCallback(boost::bind(&Message_Filter::callback, this, _1, _2));. At first, I think that it is because the publishing frequency of the two topics are different which make the code cannot enter into the callback function, but when I write another publish node which publishes two topic almost at the same time, it still not work, so I really don't know where the problem is. Does anyone knows about this? Thanks a lot.
Here is my codes:
#include "message_filter_node.h"
Message_Filter::Message_Filter()
message_filters::Subscriber<sensor_msgs::PointCloud2> Velodyne_sub(nh, "/velodyne_points", 1);
message_filters::Subscriber<sensor_msgs::LaserScan> Hokuyo_sub(nh,"/scan" , 1);
typedef sync_policies::ApproximateTime<PointCloud2, LaserScan> MySyncPolicy;
// ApproximateTime takes a queue size as its constructor argument, hence MySyncPolicy(10)
Synchronizer<MySyncPolicy> sync(MySyncPolicy(100), Velodyne_sub, Hokuyo_sub);
Velodyne_pub=nh.advertise<PointCloud2>("message_filter/velodyne_points",1);
Hokuyo_pub=nh.advertise<LaserScan>("message_filter/scan",1);
void Message_Filter::callback(const PointCloud2::ConstPtr& point_cloud2, const LaserScan::ConstPtr& laser_scan)
ROS_ERROR("Enter Publish");
Velodyne_pub.publish(point_cloud2);
Hokuyo_pub.publish(laser_scan);
Here is my header file:
#ifndef MESSAGE_FILTER_NODE_H
#define MESSAGE_FILTER_NODE_H
#include <message_filters/subscriber.h>
#include <message_filters/synchronizer.h>
#include <message_filters/sync_policies/approximate_time.h>
#include <sensor_msgs/Image.h>
#include <sensor_msgs/PointCloud2.h>
#include <sensor_msgs/LaserScan.h>
#include "image_transport/image_transport.h"
using namespace sensor_msgs;
using namespace message_filters;
class Message_Filter
public:
    Message_Filter();
    void callback(const PointCloud2::ConstPtr& point_cloud2, const LaserScan::ConstPtr& laser_scan);
public:
    ros::Publisher Velodyne_pub;
    ros::Publisher Hokuyo_pub;
    ros::NodeHandle nh;
#endif // MESSAGE_FILTER_NODE_H
Thanks Dimitri Schachmann , the problem was solved. And my codes are:
#include "ros/ros.h"
//ros::Publisher Velodyne_pub;
void callback(const sensor_msgs:: PointCloud2::ConstPtr& point_cloud2, const
sensor_msgs::LaserScan::ConstPtr& laser_scan)
   // Velodyne_pub.publish(point_cloud2);
  //  Hokuyo_pub.publish(laser_scan);
int main(int argc, char** argv)
  ros::init(argc, argv, "message_filter_node");
  ros::Time::init();
  ros::NodeHandle nh;
  ROS_INFO("start message filter");
  typedef message_filters::sync_policies::ApproximateTime<sensor_msgs::PointCloud2,
  sensor_msgs::LaserScan> MySyncPolicy;
  message_filters::Synchronizer<MySyncPolicy> sync(MySyncPolicy(10), Velodyne_sub, Hokuyo_sub);
  sync.registerCallback(boost::bind(&callback, _1, _2));
  ros::spin();
  return 0;
Originally posted by Yuxi on ROS Answers with karma: 18 on 2016-08-18
My guess would be, that it's because your subscribers are local variables and are destructed when Message_Filter::Message_Filter() returns. Try making your subscribers and your synchronizer member variables of your class.
It also depends on how your main(...) looks like, but there you also need to make sure your Message_Filter object does not go out of scope, but I suppose you have that already by blocking inros::spin()
Originally posted by Dimitri Schachmann with karma: 789 on 2016-08-19
Comment by Yuxi on 2016-08-25:
Thank you very much.!You are right. And I wrote the codes in main function and it works.
Comment by tanasis on 2017-06-13:
The question is... how should we make this a class...
Comment by Dimitri Schachmann on 2017-06-13:
Just make a normal C++ class. This is not ROS specific then.
