I'm trying to install ROS Kinetic on Ubuntu Mate 16.04 following these instructions: http://wiki.ros.org/kinetic/Installation/Ubuntu
The site says that armhf is supportet. However when executing
sudo apt-get install ros-kinetic-desktop-full
I always get the error
unable to locate package ros-kinetic-desktop-full
Same for desktop or basic install. Is there any idea what I could do?
ros-latest.list contains as first line deb http://packages.ros.org/ros/ubuntu xenial main, that should be ok...
Originally posted by Johannes Jaegers on ROS Answers with karma: 70 on 2016-08-15
Comment by Abdul Mannan on 2016-10-16:
I am alos using the Raspberry Pi 3 under Ubuntu Mate. It will be good to be in touch with you and have some discussion in this regard. I am also facing various kinds of problems, for example in the installation for rosaria. It will be good to be in touch with you for this purpose [email protected].
Try the shadow-fixed repos.
Originally posted by tonybaltovski with karma: 2549 on 2016-08-15
Comment by Johannes Jaegers on 2016-08-16:
Great, that works with the desktop version! Can you poste it as answer, then I mark as complete?
Comment by Johannes Jaegers on 2016-08-22:
I also updated the instructions that I linked above...
