I am a fresh man to ROS system.I bulid a robot platfom use ros. i use move_base in my systerm.
I have a laser scan and some ultrasonic sensors in my systerm,but for using the ultrasonic sensor i got some problem.
i dont konw how to add the range_sensor_layer as a costmap plugins.
i tried just add
In costmap_common_params.yaml
add the layer of ultrasonic
 ultrasonic_layer:
 enabled: true
 max_obstacle_height: 0.4
 origin_z: 0.0
 z_resolution: 0.2
 z_voxels: 2
 unknown_threshold: 15
 mark_threshold: 0
 combination_method: 1
 track_unknown_space: true #true needed for disabling globalpath planning through unknown space
 obstacle_range: 1.0
 raytrace_range: 3.0
 publish_voxel_map: false
 observation_sources: ultrasonic
 ultrasonic:
  data_type: Range
  topic: ultrasonic
  marking: true
  clearing: true
In local_costmap_params.yaml like
plugins:
  - {name: obstacle_layer, type: "costmap_2d::VoxelLayer"}
  - {name: ultrasonic,   type: "range_sensor_layer::RangeSensorLayer"}
  - {name: inflation_layer, type: "costmap_2d::InflationLayer"}
but when i run the move base i got some error said: "range_sensor_layer::RangeSensorLayer" is not surported by the plugin .
i can get the range informations using : $rostopic echo ultrasonic
did i missed something? or did i do somrthing wrong?
and can anybody tell me the correct way to use the range_sensor_layer as a plugin?
thanks a lot
Originally posted by zink on ROS Answers with karma: 1 on 2016-08-10
Comment by David Lu on 2016-08-21:
Can you please post the actual error message that you got?
My guess is your issue stems from how you defined your ultrasonic plugin. Try the following instead:
ultrasonic:
    topics: ["/ultrasonic"]
    no_readings_timeout: 1.0
    clear_on_max_reading: true
Then also remove all of your "ultrasonic_layer:" definition to prevent confusion (Unless you are using that plugin elsewhere). You only need to define a layer/plugin once.
Also the RangeSensorLayer has no 'marking' or 'clearing' parameters (unlike ObstacleLayer) so you don't need those lines.
Let us know if this fixes your problem.
Originally posted by biglotusturtle with karma: 165 on 2017-09-20
