When i try to install the ar_track_alvar using sudo apt-get install ros-indigo-ar-track-alvar
I was getting the following error.
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-indigo-ar-track-alvar
I also tried using synaptic tool which is alternative to apt-get install. But i was not able to find indigo related alvar packages image description
Can anyone please help me on this?
Originally posted by anilmullapudi on ROS Answers with karma: 75 on 2016-08-09
Comment by ahendrix on 2016-08-09:
ar_track_alvar is listed as released for Indigo, so that should work if you're using Indigo that was installed through apt on Ubuntu x86. Perhaps you're using a different OS or a different CPU?
Comment by anilmullapudi on 2016-08-09:
Here is my OS details
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.5 LTS
Release: 14.04
Codename: trusty
The build status page and the arm build status page show that ar_track_alvar is built and stable for Ubuntu Trusty x86, amd64 and armhf architectures,
Did you install ROS through apt or from source? Are your apt sources set up correctly?
Your system reports that it's running Ubuntu 14.04 (Trusty), but the ROS packages listed are for Ubuntu 12.04 (Precise). Did you have a previous version of ROS installed? Did you upgrade from a previous version of Ubuntu?
ROS was installed through apt-get
rosversion -d
indigo
Thank you so much for your support, i re-installed the ros indigo keys. i was able to install the ar_track_alvar now.
I followed 1.2 and 1.3 from this link http://wiki.ros.org/indigo/Installation/Ubuntu and sudo apt-get update
above steps worked for me, now i was able to install
Originally posted by anilmullapudi with karma: 75 on 2016-08-09
