Ubuntu 14.04, ROS Indigo.
I've been following along with the tutorial at: http://wiki.ros.org/ROS/Tutorials/CreatingMsgAndSrv and when I get to the portion where it instructs me to run catkin_make install I get:
Base path: /home/umdearborn/catkin_ws
Source space: /home/umdearborn/catkin_ws/src
Build space: /home/umdearborn/catkin_ws/build
Devel space: /home/umdearborn/catkin_ws/devel
Install space: /home/umdearborn/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/umdearborn/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/umdearborn/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/umdearborn/catkin_ws/devel;/opt/ros/indigo
-- This workspace overlays: /home/umdearborn/catkin_ws/devel;/opt/ros/indigo
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/umdearborn/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.6.18
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 1 packages in topological order:
-- ~~  - beginner_tutorials
-- +++ processing catkin package: 'beginner_tutorials'
-- ==> add_subdirectory(beginner_tutorials)
-- Using these message generators: gencpp;geneus;genlisp;genpy
CMake Error at beginner_tutorials/CMakeLists.txt:61 (add_action_files):
  Unknown CMake command "add_action_files".
See also "/home/umdearborn/catkin_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/umdearborn/catkin_ws/build/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
I'm fairly new to ROS and CMake so I'm completely stumped. I've made sure to source both /opt/ros/indigo/setup.bash and ~/catkin_ws/devel/setup.bash.
Any ideas what could be causing this?
Originally posted by Distractal on ROS Answers with karma: 3 on 2016-07-23
It looks like you have add_action_files on line 61 of your CMakeLists.txt, and cmake doesn't understand that command.
I don't see any mention of it in the tutorial, so you should probably comment out that command.
(for background, the add_action_files command is part of actionlib and is used for generating action interfaces, which are a more advanced topic)
Originally posted by ahendrix with karma: 47576 on 2016-07-23
Comment by Distractal on 2016-07-23:
You were correct, I mistakenly placed the AddTwoInts.srv line under the add_action_files directive instead of the add_service_files directive. Thank you!
If someone is facing a similar error check your find_package if actionlib_msgs are added, and also in generate_messages part, that solved this error for
Originally posted by Siddarth09 with karma: 11 on 2021-07-24
