Hi... I am to ROS and i would be posting lots of questions. :) Th thing i am trying to do is that i want to create multiple packages inside single catkin workspace. I created my package "my_first_pkg" inside "catkin_ws/src". It worked fine. Then i tried to add another package in the same "catkin_ws/src" with the name "my_second_pkg" using "catkin_create_pkg". Then i run following command
catkin_make
it gives me following error. Invoking "make cmake_check_build_system" failed
Originally posted by UsmanArif on ROS Answers with karma: 41 on 2016-07-21
Comment by ahendrix on 2016-07-21:
It sounds like there is more than just one line in this error message; please edit your question to include the full error message.
Hi. Thanks for the reply. I found the error. There was problem with the other packages in the same workspace. One of the other package had wrong cmakelist.txt file..
Originally posted by UsmanArif with karma: 41 on 2016-07-21
