Hi, I have two catkin packages, one generating a library and the other makes use of it. In the cmake file of the dependent project, I have "link_directories( ${CATKIN_DEVEL_PREFIX}/lib/ )". This works fine with catkin_make, as the libxxx.so gets generated in devel/lib/. However when using catkin_make_isolated, the libxxx.so gets generated in devel_isolated/project_xxx/lib/ instead. And ${CATKIN_DEVEL_PREFIX} does not seem to dynamically substitute with the correct path according to the catkin command used. What cmake or catkin variable should I use for the link_directories to work in both cases?
Originally posted by blueberry on ROS Answers with karma: 3 on 2016-07-19
You should not use link_directories at all.
In the package where you create the library:
  • export the library and the headers in the catkin_package call
  • install the library and the headers
in the package where you use it:
  • find_pacakge the pacakge above
  • use target_link_libraries(TARGET ${catkin_LIBRARIES}) and include_directores(${catkin_INCLUDE_DIRS})`
Originally posted by mgruhler with karma: 12390 on 2016-07-20
Comment by anonymous29979 on 2018-09-07:
For an explanation on why this works, read http://wiki.ros.org/catkin/CMakeLists.txt#Why_Are_Catkin_Packages_Specified_as_Components.3F
