Hey guys,
I'm using an XV-11 and IMU to create a 3D sensor_msgs::PointCloud which is successfully advertised on a topic. I want to convert that cloud into a sensor_msgs::PointCloud2 and then pcl::PointCloud. I would also like to convert the intensities into RGB values, but I was having too many problems accessing/editing the rgb values for pcl::PointCloudpcl::PointXYZRGB. So, I ended up with this code for just the XYZ values...
    sensor_msgs::PointCloud cloud_out;
    sensor_msgs::PointCloud2 cloud2_out;
... calculations and unnecessary code omitted
    sensor_msgs::convertPointCloudToPointCloud2 (cloud_out, cloud2_out);
    pcl::PointCloud<pcl::PointXYZ> pcl_cloud;
    pcl::fromROSMsg(cloud2_out, pcl_cloud);
    pcl::io::savePCDFileASCII ("test_pcd123.pcd", pcl_cloud);
which compiles and runs without any errors, except that test_pcd123.pcd cannot be found anywhere on my computer. Any ideas on what's going wrong?
When I use std::cerr << "Saved " << pcl_cloud.points.size () << " data points to test_pcd.pcd." << std::endl;, a correct message of Saved 360 data points to test_pcd.pcd. is shown
Originally posted by ateator on ROS Answers with karma: 37 on 2016-07-19
Made a minor change, now it works
    writeCount++;
    char filename[100];
    sprintf(filename, "/home/ateator/catkin_ws/src/laser_assembler/src/outputpcd/output%dx.pcd", writeCount);
    pcl::io::savePCDFileASCII (filename, pcl_cloud);
Originally posted by ateator with karma: 37 on 2016-07-19
