Hey I have the following subscriber:
ImageConverter(ros::NodeHandle &n) :  n_(n), it_(n_)
  image_pub_ = it_.advertise("/output_img",1);
  cv::namedWindow(OPENCV_WINDOW);
  image_transport::TransportHints TH("compressed");
  image_sub_compressed.subscribe(n,"/Logitech_webcam/image_raw/compressed",5,&ImageConverter::imageCallback,ros::VoidPtr(),TH);
And the callback function
void imageCallback(const sensor_msgs::CompressedImageConstPtr& msg)
When I compile this I get an error:
from /home/johann/catkin_ws/src/uncompressimage/src/publisher_uncompressed_images.cpp:1:
/usr/include/boost/function/function_template.hpp: In instantiation of ‘static void boost::detail::function::function_void_mem_invoker1<MemberPtr, R, T0>::invoke(boost::detail::function::function_buffer&, T0) [with MemberPtr = void (ImageConverter::*)(const boost::shared_ptr<const sensor_msgs::CompressedImage_<std::allocator<void> > >&); R = void; T0 = const boost::shared_ptr<const sensor_msgs::Image_<std::allocator<void> > >&]’:
/usr/include/boost/function/function_template.hpp:934:38:   required from ‘void boost::function1<R, T1>::assign_to(Functor) [with Functor = void (ImageConverter::*)(const boost::shared_ptr<const sensor_msgs::CompressedImage_<std::allocator<void> > >&); R = void; T0 = const boost::shared_ptr<const sensor_msgs::Image_<std::allocator<void> > >&]’
/usr/include/boost/function/function_template.hpp:722:7:   required from ‘boost::function1<R, T1>::function1(Functor, typename boost::enable_if_c<boost::type_traits::ice_not<boost::is_integral<Functor>::value>::value, int>::type) [with Functor = void (ImageConverter::*)(const boost::shared_ptr<const sensor_msgs::CompressedImage_<std::allocator<void> > >&); R = void; T0 = const boost::shared_ptr<const sensor_msgs::Image_<std::allocator<void> > >&; typename boost::enable_if_c<boost::type_traits::ice_not<boost::is_integral<Functor>::value>::value, int>::type = int]’
/usr/include/boost/function/function_template.hpp:1069:16:   required from ‘boost::function<R(T0)>::function(Functor, typename boost::enable_if_c<boost::type_traits::ice_not<boost::is_integral<Functor>::value>::value, int>::type) [with Functor = void (ImageConverter::*)(const boost::shared_ptr<const sensor_msgs::CompressedImage_<std::allocator<void> > >&); R = void; T0 = const boost::shared_ptr<const sensor_msgs::Image_<std::allocator<void> > >&; typename boost::enable_if_c<boost::type_traits::ice_not<boost::is_integral<Functor>::value>::value, int>::type = int]’
/home/johann/catkin_ws/src/uncompressimage/src/publisher_uncompressed_images.cpp:27:126:   required from here
The red error statement was:
/usr/include/boost/function/function_template.hpp:225:11: error: no match for call to ‘(boost::_mfi::mf1<void, ImageConverter, const boost::shared_ptr<const sensor_msgs::CompressedImage_<std::allocator<void> > >&>) (const boost::shared_ptr<const sensor_msgs::Image_<std::allocator<void> > >&)’
           BOOST_FUNCTION_RETURN(boost::mem_fn(*f)(BOOST_FUNCTION_ARGS));
I am not using BOOST, and searching around hasn't helped me solve it, this is how I think it should be based on reading the github for the sensor_msgs::compressedImages, if another method exists that is better?
Originally posted by jtim on ROS Answers with karma: 153 on 2016-07-15
Read the source code:
https://github.com/ros-perception/image_common/tree/hydro-devel/image_transport/src
const sensor_msgs::CompressedImageConstPtr& compressedImg outputImg = cv::imdecode(cv::Mat(compressedImg->data), CV_LOAD_IMAGE_UNCHANGED);
Originally posted by soulslicer with karma: 61 on 2016-07-15
Comment by jtim on 2016-07-17:
@soulslicer Can't seem to find it in the source could you specify the file? Also the code you refer, creates and const pointer to a compressedImg data? Seems to be some wrong with the code? Also the idea was to decompress the image? so from Sensor_msgs::CompressedImage to Sensor_msgs::Image.
Comment by jtim on 2016-07-18:
@soulslicer I am not able to find the code you refer to, can you be more precise?
ended up recompiling opencv and ros from source, the error was removed. However the subscription didn't work. Therefore I subscribed to the raw image that I had republished in a launch file. Now everything works.
Originally posted by jtim with karma: 153 on 2016-07-29
