My plan is having ROS nodes on Linux and on LabVIEW RT (MyRIO) work together with ROS master running on Linux. Currently, I am using the ROS LabVIEW library from Tufts university. I tested and proved success to be able run roscore on Linux communicating with ros node on LabVIEW PC (non-RT). But I don't have success communication between roscore runs on Linux and ros node runs on MyRIO (RT). If anyone know how to make this work please have me with instructions.
Thank you in advance.
Edit 1: The subscriber in LabVIEW RT cannot receive message from publisher in Linux (ROS master run on Linux). I also tried with ROS master run on PC, publisher run on LabVIEW PC and subscriber run on LabVIEW RT. The subscriber in this case does not receive message from publisher either. But if I ran the ROS master in LabVIEW RT, I can receive message from publisher run on LabVIEW PC.
Originally posted by Thang Nguyen on ROS Answers with karma: 93 on 2016-07-15
Comment by gvdhoorn on 2016-07-15:\
Could you add what doesn't work in this case?
Comment by Thang Nguyen on 2016-07-15:
@gvdhoorn: I added detail in my question.
If this was two Linux PCs, I would guess this is a configuration issue. What are the values of ROS_HOSTNAME, ROS_IP and ROS_MASTER_URI on all machines involved?
The current update allows me to communicate successful between Linux host and MyRIO.
Originally posted by Thang Nguyen with karma: 93 on 2016-09-20
Comment by Raphaelaasilva on 2016-12-05:
How did you do the communication between ROS/linux and myRIO? Can you share step by step?
Comment by Thang Nguyen on 2016-12-05:
If you download the code, there is a tutorial in the example shows you step by step how to do that. Regards
Sorry, what code? which tutorial? can you send the links? I'm trying to follow some infos I've found on internet here and there and in the tool kit from Tufts university and I communicate successfully ROS/linux and labview/PC, however myRIO not yet.
Comment by Muda on 2017-07-12:
Hey, I know this is an old post, but I ned to conenct ROS to myRIO wirelessly.
Any chance you can share that code that you mentioned in your comment???????
Thanks in advance.
