I need to create a custom message for a PTZ camera so I can post the pan, tilt and zoom values to a topic. The problem is that I can't generate any access methods to change them. My message is defined like this:
std_msgs/Header header
float32 pan
float32 tilt
float32 zoom
Below is the generated header, but includes no methods for setting any of my defined values.
// Generated by gencpp from file ros_pantiltzoom_tardec/PTZ.msg
// DO NOT EDIT!
#ifndef ROS_PANTILTZOOM_TARDEC_MESSAGE_PTZ_H
#define ROS_PANTILTZOOM_TARDEC_MESSAGE_PTZ_H
#include
#include
#include
#include
#include
#include
#include
#include
namespace ros_pantiltzoom_tardec
template
struct PTZ_
  typedef PTZ_ Type;
  PTZ_()
    : header()
    , pan(0.0)
    , tilt(0.0)
    , zoom(0.0)  {
  PTZ_(const ContainerAllocator& _alloc)
    : header(_alloc)
    , pan(0.0)
    , tilt(0.0)
    , zoom(0.0)  {
  (void)_alloc;
   typedef  ::std_msgs::Header_  _header_type;
  _header_type header;
   typedef float _pan_type;
  _pan_type pan;
   typedef float _tilt_type;
  _tilt_type tilt;
   typedef float _zoom_type;
  _zoom_type zoom;
  typedef boost::shared_ptr > Ptr;
  typedef boost::shared_ptr const> ConstPtr;
}; // struct PTZ_
typedef ::ros_pantiltzoom_tardec::PTZ_ > PTZ;
typedef boost::shared_ptr PTZPtr;
typedef boost::shared_ptr PTZConstPtr;
// constants requiring out of line definition
template
std::ostream& operator & v)
ros::message_operations::Printer >::stream(s, "", v);
return s;
} // namespace ros_pantiltzoom_tardec
namespace ros
namespace message_traits
// BOOLTRAITS {'IsFixedSize': False, 'IsMessage': True, 'HasHeader': True}
// {'std_msgs': ['/opt/ros/indigo/share/std_msgs/cmake/../msg'], 'roscpp': ['/opt/ros/indigo/share/roscpp/cmake/../msg'], 'ros_pantiltzoom_tardec': ['/home/brenton/jaustoolset/autogenerated/PanTiltZoomCamera_41/msg']}
// !!!!!!!!!!! ['__class__', '__delattr__', '__dict__', '__doc__', '__eq__', '__format__', '__getattribute__', '__hash__', '__init__', '__module__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', '_parsed_fields', 'constants', 'fields', 'full_name', 'has_header', 'header_present', 'names', 'package', 'parsed_fields', 'short_name', 'text', 'types']
template
struct IsFixedSize >
  : FalseType
template
struct IsFixedSize const>
  : FalseType
template
struct IsMessage >
  : TrueType
template
struct IsMessage const>
  : TrueType
template
struct HasHeader >
  : TrueType
template
struct HasHeader const>
  : TrueType
template
struct MD5Sum >
  static const char* value()
    return "163a943a2132dce8f0610e78f5487c99";
  static const char* value(const ::ros_pantiltzoom_tardec::PTZ_&) { return value(); }
  static const uint64_t static_value1 = 0x163a943a2132dce8ULL;
  static const uint64_t static_value2 = 0xf0610e78f5487c99ULL;
template
struct DataType >
    return "ros_pantiltzoom_tardec/PTZ";
template
struct Definition >
    return "std_msgs/Header header\n\
float32 pan\n\
float32 tilt\n\
float32 zoom\n\
\n\
================================================================================\n\
MSG: std_msgs/Header\n\
# Standard metadata for higher-level stamped data types.\n\
# This is generally used to communicate timestamped data \n\
# in a particular coordinate frame.\n\
# \n\
# sequence ID: consecutively increasing ID \n\
uint32 seq\n\
#Two-integer timestamp that is expressed as:\n\
# * stamp.sec: seconds (stamp_secs) since epoch (in Python the variable is called 'secs')\n\
# * stamp.nsec: nanoseconds since stamp_secs (in Python the variable is called 'nsecs')\n\
# time-handling sugar is provided by the client library\n\
time stamp\n\
#Frame this data is associated with\n\
# 0: no frame\n\
# 1: global frame\n\
string frame_id\n\
} // namespace message_traits
} // namespace ros
namespace ros
namespace serialization
  template struct Serializer >
    template inline static void allInOne(Stream& stream, T m)
      stream.next(m.header);
      stream.next(m.pan);
      stream.next(m.tilt);
      stream.next(m.zoom);
    ROS_DECLARE_ALLINONE_SERIALIZER;
  }; // struct PTZ_
} // namespace serialization
} // namespace ros
namespace ros
namespace message_operations
template
struct Printer >
  template static void stream(Stream& s, const std::string& indent, const ::ros_pantiltzoom_tardec::PTZ_& v)
    s  >::stream(s, indent + "  ", v.header);
    s ::stream(s, indent + "  ", v.pan);
    s ::stream(s, indent + "  ", v.tilt);
    s ::stream(s, indent + "  ", v.zoom);
} // namespace message_operations
} // namespace ros
#endif // ROS_PANTILTZOOM_TARDEC_MESSAGE_PTZ_H
Originally posted by Brenton on ROS Answers with karma: 1 on 2016-07-06
ROS messages don't use getters or setters. Instead, all fields are public (in C++ anyway), and you should set them as you would do any other variable (ie: my_msg.a.b.c = 3).
Originally posted by gvdhoorn with karma: 86574 on 2016-07-07
