I've got this driver: http://www.pololu.com/catalog/product/1182
... a A4988 stepper motor driver carrier
I'm attempting to control a connection between the RESET and SLEEP pins with logic ( code ) running on my Arduino. The motor runs perfectly when these two pins are connected however I'd like to control when the stepper is powered off from my Arduino ( and thus not generating extra heat )
I'd like to:
- designate a pin to control the connection between these two pins
- use a "digitalWrite" to the above pin with a HIGH or LOW to switch power on and off from the stepper
NOTE: The data sheet mentioned that for the driver to be powering the stepper both RESET and SLEEP needed to be in switched on ( HIGH )
