I am running ubuntu 16.04, with kinetic for xbox, using a kinect for point cloud data. I want to generate a map, but I cannot figure out how to make a map of an environment. I am hoping that I can use the kinect and spoof the odometry and rotation from the video from the kinect. I am using freenect because I have read that openni/openni2 are no longer supporting kinect. I have ran:roslaunch freenect_launch freenect.launch, then rosrun rviz rviz, and am able to get some point cloud data. I have tried to change the different settings for the referenced frame portions from the kinect in order to try to get map data.
So, Is there a way I can make a map with just the kinect and no "real" odometry, (pretty much without a robot connected). What are the steps to build a map? And if I am asking horribly bad questions (or even if the questions aren't too bad) to people and should be using the wiki, how am I supposed to know what I need to do to find the answers on my own.
Thank you.
Originally posted by matrhint on ROS Answers with karma: 52 on 2016-07-04
Yes, it is possible to generate a map using only a Kinect.
My suggestion would be to familiarize yourself with the various packages available, understand what they do, what data they require, pros, cons, etc.. This requires you do some research on your own, but it will help you.
For instance, if you want to perform SLAM there are two packages that come to mind: gmapping, and hector_mapping. By looking at the published topics they both give you the map that you desire, but they differ in the subscribed topics (i.e. the data that they require). The point I am trying to make is that you can start filling in the gaps to be able to use these packages.
With gmapping you need odometry, and if you look around there is a package called laser_scan_matcher that can "fake" odometry data from laser scans. So the next step is to produce a laser scan from the kinect, which can be achieved with depthimage_to_laserscan or pointcloud_to_laserscan.
hector_mapping does not require odometry, but it does require scan data, which you already know how to get from the gmapping description above.
I'm not able to give you step-by-step instructions on how to do this, and there are obviously some steps missing in my breif description above. But if you do some searches related to the above packages and kinect sensors you should be able to find enough info about how to do this, as well as the pros and cons about different approaches. After a quick look here are some similar answers that may help you:
2D SLAM with gmapping and openni_kinect
how to create a 2D map from laser scan data
SLAM without odometry: gmapping or hector_slam?
Originally posted by Steven_Daniluk with karma: 606 on 2016-07-05
Comment by matrhint on 2016-07-05:
Thank you so much for your help.
