hello i have previously connected my ROS (Ubuntu) with an arduino uno via bluetooth and publish data from the arduino and view it by using rostopic echo but now i want to do the same thing but by using wifi i want to connect my arduino with a wifi router and communicate with ROS via wifi how can i do that... i seriously need help to get my project done
Originally posted by naqi.nick on ROS Answers with karma: 62 on 2016-07-02
Hi,
If you plan to use WiFi you will have to make sure that you can ping all components on the network. In other words, properly set up your network. I would say there must be a set up guide for the Arduino/shield on the web to do so.
Then, start sending UDP packages (or the protocol that suits your application) from your Arduino to one node in ROS.
Cheers
Originally posted by Nexus8 with karma: 106 on 2016-07-03
